Layout 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 814| 评论: 0|原作者: admin|来自: AutoCAD
Layout 属性 (ActiveX)
指定与模型空间、图纸空间或块对象关联的布局。
object.Layout
类型:块、模型空间、纸空间
此属性应用于的对象。
只读:不
类型: 布局
该对象包含模型空间、图纸空间或块对象的打印设置。Layout
未与给定块关联的命名绘图设置将存储为对象。PlotConfiguration
Sub Example_Layout()
    ' This example references the Layout object obtained from model space.
    ' We then display information from the Layout object.
    Dim Layout As ACADLayout
    ' Attach to Layout object
    Set Layout = ThisDrawing.ModelSpace.Layout
    MsgBox "We now have access to the properties and methods of the model space Layout object!"
    ' Retrieve the name of the model space Layout
    MsgBox "The name of the model space Layout is: " & Layout.name
(defun c:Example_Layout()
    ;; This example references the Layout object obtained from model space.
    ;; We then display information from the Layout object.
    ;; Attach to Layout object
    (setq Layout (vla-get-Layout (vla-get-ModelSpace doc)))
    (alert "We now have access to the properties and methods of the model space Layout object!")
    ;; Retrieve the name of the model space Layout
    (alert (strcat "The name of the model space Layout is: " (vla-get-Name Layout.name)))
GMT+8, 2026-10-27 09:51
