LargeButtons 属性 (ActiveX)
指定工具栏按钮是大还是小。 支持的平台:仅限 Windows 属性值只读:是的;除了读写的集合Toolbars 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_LargeButtons()
' This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
' It then creates a new Toolbar (TestMenu) and inserts a ToolBarButton
' into it. It then sets the LargeButtons property to change the visible style
' of all the system Toolbars
Dim CurrSize As Boolean, ButtonSize As String
Dim Toolbars As AcadToolbars
' Make the system Toolbar buttons bigger
Set Toolbars = ThisDrawing.Application.MenuGroups("ACAD").Toolbars
' Get current size
CurrSize = Toolbars.LargeButtons
' Display current Toolbar size
GoSub DISPLAY
' Toggle Toolbar size
Toolbars.LargeButtons = Not (Toolbars.LargeButtons)
GoSub DISPLAY
' Reset to original value
Toolbars.LargeButtons = CurrSize
GoSub DISPLAY
Exit Sub
DISPLAY:
' Display button style
ButtonSize = IIf(Toolbars.LargeButtons, "Large", "Normal size")
MsgBox "We are displaying " & ButtonSize & " buttons.", vbInformation
Return
可视化 LISP: (vl-load-com)
(defun c:Example_LargeButtons()
;; This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
;; It then creates a new Toolbar (TestMenu) and inserts a ToolBarButton
;; into it. It then sets the LargeButtons property to change the visible style
;; of all the system Toolbars
;; Make the system Toolbar buttons bigger
(setq Toolbars (vla-get-Toolbars (vla-Item (vla-get-MenuGroups acadObj) "ACAD")))
;; Get current size
(setq CurrSize (vla-get-LargeButtons Toolbars))
;; Display current Toolbar size
(setq ButtonSize (if (= CurrSize :vlax-true) "Large" "Normal size"))
(alert (strcat "We are displaying " ButtonSize " buttons."))
;; Toggle Toolbar size
(vla-put-LargeButtons Toolbars (if (= (vla-get-LargeButtons Toolbars) :vlax-true) :vlax-false :vlax-true))
(setq ButtonSize (if (= (vla-get-LargeButtons Toolbars) :vlax-true) "Large" "Normal size"))
;; Reset to original value
(vla-put-LargeButtons Toolbars CurrSize)
GMT+8, 2026-10-27 01:23
