Knots 属性 (ActiveX)
获取样条曲线的结向量。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打的三元素阵列) 样条曲线的结向量。 言论没有其他评论。 例子VBA: Sub Example_Knots()
' This example creates a Spline object in model space and
' returns the knot vector for the new Spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
Dim knotVector As Variant
' Define the Spline object
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0: fitPoints(3) = 5
fitPoints(4) = 5: fitPoints(5) = 0: fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
' Create new Spline object
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
' Display the knot vector of the new Spline
knotVector = splineObj.Knots
MsgBox "The knot vector of the new Spline is: " & vbCrLf & _
knotVector(0) & vbCrLf & _
knotVector(1) & vbCrLf & _
knotVector(2)
可视化 LISP: (vl-load-com)
(defun c:Example_Knots()
;; This example creates a Spline object in model space and
;; returns the knot vector for the new Spline
;; Define the Spline object
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(0 0 0
5 5 0
10 0 0
;; Create new Spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display the knot vector of the new Spline
(setq knotVector (vlax-safearray->list (vlax-variant-value (vla-get-Knots splineObj))))
(alert (strcat "The knot vector of the new Spline is: "
"\n" (rtos (nth 0 knotVector) 2)
"\n" (rtos (nth 1 knotVector) 2)
"\n" (rtos (nth 2 knotVector) 2)))
GMT+8, 2026-10-27 05:45
