KeyboardAccelerator 属性 (ActiveX)
指定 Windows 标准键盘或 AutoCAD 经典键盘。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acKeyboardAccelerator
言论没有其他评论。 例子VBA: Sub Example_KeyboardAccelerator()
' KeyboardAccelerator. It then changes the value, and finally
Dim currKeyboardAccelerator As Integer
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current KeyboardAccelerator value
currKeyboardAccelerator = preferences.User.KeyboardAccelerator
MsgBox "The current value for KeyboardAccelerator is " & currKeyboardAccelerator, vbInformation, "KeyboardAccelerator Example"
' Change the value for KeyboardAccelerator
If currKeyboardAccelerator = acPreferenceClassic Then
preferences.User.KeyboardAccelerator = acPreferenceCustom
Else
preferences.User.KeyboardAccelerator = acPreferenceClassic
End If
MsgBox "The new value for KeyboardAccelerator is " & preferences.User.KeyboardAccelerator, vbInformation, "KeyboardAccelerator Example"
' Reset KeyboardAccelerator to its original value
preferences.User.KeyboardAccelerator = currKeyboardAccelerator
MsgBox "The KeyboardAccelerator value is reset to " & preferences.User.KeyboardAccelerator, vbInformation, "KeyboardAccelerator Example"
可视化 LISP: (vl-load-com)
(defun c:Example_KeyboardAccelerator()
;; KeyboardAccelerator. It then changes the value, and finally
;; Retrieve the current KeyboardAccelerator value
(setq currKeyboardAccelerator (vla-get-KeyboardAccelerator (vla-get-User preferences)))
(alert (strcat "The current value for KeyboardAccelerator is " (if (= currKeyboardAccelerator acPreferenceClassic) "Classic" "Custom")))
;; Change the value for KeyboardAccelerator
(vla-put-KeyboardAccelerator (vla-get-User preferences) acPreferenceCustom)
(vla-put-KeyboardAccelerator (vla-get-User preferences) acPreferenceClassic)
(alert (strcat "The new value for KeyboardAccelerator is " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) acPreferenceClassic) "Classic" "Custom")))
;; Reset KeyboardAccelerator to its original value
(vla-put-KeyboardAccelerator (vla-get-User preferences) currKeyboardAccelerator)
(alert (strcat "The KeyboardAccelerator value is reset to " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) acPreferenceClassic) "Classic" "Custom")))
GMT+8, 2026-10-27 05:31
