IsQuiescent 属性 (ActiveX)
检查AutoCAD是否处于空闲状态并准备好接受来自进程外应用程序的自动化调用。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_IsQuiescent()
' This example gets the acadState object and checks to see whether
' AutoCAD is in a quiescent state.
Dim State As AcadState
Set State = GetAcadState
If State.IsQuiescent Then
MsgBox "AutoCAD is quiescent."
Else
MsgBox "AutoCAD is not quiescent."
End If
可视化 LISP: (vl-load-com)
(defun c:Example_IsQuiescent()
;; This example gets the acadState object and checks to see if
;; AutoCAD is in a quiescent state.
(setq State (vla-GetAcadState acadObj))
(if (= (vla-get-IsQuiescent State) :vlax-true)
(alert "AutoCAD is quiescent.")
(alert "AutoCAD is not quiescent.")
GMT+8, 2026-10-27 05:24
