IsPlanar 属性 (ActiveX)
确定给定样条是否为平面样条。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_IsPlanar()
' This example creates a Spline object in model space and
' determines whether the Spline is planar
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
Dim UserMessage As String
' Define the Spline object
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0: fitPoints(3) = 5
fitPoints(4) = 5: fitPoints(5) = 0: fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
' Create new Spline object
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
' Display whether or not new Spline is planar
UserMessage = IIf(splineObj.IsPlanar, "is planar", "is not planar")
MsgBox "The new Spline " & UserMessage
可视化 LISP: (vl-load-com)
(defun c:Example_IsPlanar()
;; This example creates a Spline object in model space and
;; determines whether the Spline is planar
;; Define the Spline object
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(0 0 0
5 5 0
10 0 0
;; Create new Spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display whether or not new Spline is planar
(setq UserMessage (if (= (vla-get-IsPlanar splineObj) :vlax-true) "is planar" "is not planar"))
(alert (strcat "The new Spline " UserMessage))
GMT+8, 2026-10-28 05:29
