IsPeriodic 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 886| 评论: 0|原作者: admin|来自: AutoCAD
确定给定样条是否为周期性样条曲线。
object.IsPeriodic
类型:样条曲线
此属性应用于的对象。
只读:是的
类型:布尔
  • True:样条曲线是周期性的。
  • False:样条曲线不是周期性的。
Sub Example_IsPeriodic()
    ' This example creates a Spline object in model space and
    ' determines if the Spline is periodic
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    Dim UserMessage As String
    ' Define the Spline object
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0: fitPoints(3) = 5
    fitPoints(4) = 5: fitPoints(5) = 0: fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    ' Create new Spline object
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ' Display whether or not new Spline is periodic
    UserMessage = IIf(splineObj.IsPeriodic, "is periodic", "is not periodic")
    MsgBox "The new Spline " & UserMessage
(defun c:Example_IsPeriodic()
    ;; This example creates a Spline object in model space and
    ;; determines if the Spline is periodic
    ;; Define the Spline object
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display whether or not new Spline is periodic
    (setq UserMessage (if (= (vla-get-IsPeriodic splineObj) :vlax-true) "is periodic" "is not periodic"))
    (alert (strcat "The new Spline " UserMessage))
GMT+8, 2026-10-27 09:03
