IsCloned 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 621| 评论: 0|原作者: admin|来自: AutoCAD
确定是否已克隆 CopyObjects 操作中的源对象。
object.IsCloned
类型: IDPair
此属性应用于的对象。
只读:是的
类型:布尔
  • True:源对象已克隆。
  • False:源对象尚未克隆。
Sub Example_IsCloned()
    ' This example creates a Circle object and uses the CopyObjects
    ' method to copy the Circle. It then displays some information
    ' about the source objects used in the CopyObjects operation.
    Dim circleObj As AcadCircle, circleObjCopy As AcadCircle
    Dim radius1 As Double, radius1Copy As Double
    Dim objCollection(0 To 0) As Object
    Dim retObjects As Variant
    Dim IDPairs As Variant
    Dim IsClonedState As String, IsPrimary As String, IsXLated As String
    ' Define the Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius1 = 5#: radius1Copy = 1#
    ' Add two circles to the drawing
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius1)
    ' Copy objects
    ' First put the objects to be copied into a form compatible with CopyObjects
    Set objCollection(0) = circleObj
    ' Copy object and get back a collection of the new objects
    retObjects = ThisDrawing.CopyObjects(objCollection, , IDPairs)
    ' Get newly created object and apply new properties to the copies
    Set circleObjCopy = retObjects(0)
    circleObjCopy.radius = radius1Copy
    ' Display whether the first source object has a clone
    IsClonedState = IIf(IDPairs(0).IsCloned, "is cloned.", "is not cloned.")
    IsPrimary = IIf(IDPairs(0).IsPrimary, "is a primary member of the objects being copied.", "is owned by a primary member of the objects being copied.")
    IsXLated = IIf(IDPairs(0).IsOwnerXlated, "has been translated.", "has not been translated.")
    MsgBox "The new Circle source object: " & IsClonedState & vbCrLf & _
           "The new Circle source object: " & IsPrimary & vbCrLf & _
           "The source of the new Circle object: " & IsXLated & vbCrLf, vbInformation
(defun c:Example_IsCloned()
    ;; This example creates a Circle object and uses the CopyObjects
    ;; method to make a copy of the Circle. It then displays some information
    ;; about the source objects used in the CopyObjects operation.
    ;; Define the Circle object
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius1 5
          radius1Copy 1)
    ;; Add two circles to the drawing
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius1))
    (vla-ZoomAll acadObj)
    ;; Copy objects
    ;; First put the objects to be copied into a form compatible with CopyObjects
    (setq objCollection (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (vlax-safearray-put-element objCollection 0 circleObj)
    ;; Copy object and get back a collection of the new objects (copies)
    (setq retObjects (vla-CopyObjects doc objCollection nil 'IDPairs))
    ;; Get newly created object and apply new properties to the copies
    (setq circleObjCopy (vlax-safearray-get-element (vlax-variant-value retObjects) 0))
    (vla-put-radius circleObjCopy radius1Copy)
    ;; Display whether the first source object has a clone
    (setq IsClonedState (if (= (vla-get-IsCloned (vlax-safearray-get-element IDPairs 0)) :vlax-true) "is cloned."
        "is not cloned."))
    (setq IsPrimary (if (= (vla-get-IsPrimary (vlax-safearray-get-element IDPairs 0)) :vlax-true) "is a primary member of the objects being copied."
        "is owned by a primary member of the objects being copied."))
    (setq IsXLated (if (= (vla-get-IsOwnerXlated (vlax-safearray-get-element IDPairs 0)) :vlax-true) "has been translated."
        "has not been translated."))
    (alert (strcat "The new Circle source object: " IsClonedState
                   "\nThe new Circle source object: " IsPrimary
                   "\nThe source of the new Circle object: " IsXLated))
GMT+8, 2026-10-27 11:30
