Invisible 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 675| 评论: 0|原作者: admin|来自: AutoCAD
指定属性或属性引用是否不可见。
object.Invisible
类型:Attribute、AttributeReference
此属性应用于的对象。
只读:不
类型:布尔
  • True:该属性是不可见的属性。
  • False:该属性不是不可见属性。
不会显示或绘制不可见属性。
属性只能作为四种可选模式之一存在:常量、预设、不可见或验证。AFLAGS 系统变量存储当前模式设置。可以使用该属性查询当前模式。Mode
Sub Example_Invisible()
    ' This example creates an attribute definition in model space.
    ' It then queries the visibility of the attribute, changes
    ' the visibility, and queries the visibility again.
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    ' Define the attribute definition
    height = 1#
    mode = acAttributeModeVerify
    prompt = "New Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "New_Tag"
    value = "New Value"
    ' Create the attribute definition object in model space
    Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ZoomAll
    ' Find the current visibility for the attribute
    GoSub QUERYSTATUS
    ' Change the visibility of the attribute
    attributeObj.Invisible = Not attributeObj.Invisible
    ZoomAll
    GoSub QUERYSTATUS
    Exit Sub
QUERYSTATUS:
    If attributeObj.Invisible Then
        MsgBox "The attribute is invisible."
    Else
        MsgBox "The attribute is visible."
    End If
    Return
(defun c:Example_Invisible()
    ;; This example creates an attribute definition in model space.
    ;; It then queries the visibility of the attribute, changes
    ;; the visibility, and queries the visibility again.
    ;; Define the attribute definition
    (setq insertionPoint (vlax-3d-point 5 5 0)
          attHeight 1
          attMode acAttributeModeVerify
          attPrompt "New Prompt"
          attTag "NEW_TAG"
          attValue "New Value")
    ;; Create the attribute definition object in model space
    (setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
    (vla-ZoomAll acadObj)
    ;; Find the current visibility for the attribute
    (if (= (vla-get-Invisible attributeObj) :vlax-true)
        (alert "The attribute is invisible.")
        (alert "The attribute is visible.")
    ;; Change the visibility of the attribute
    (vla-put-Invisible attributeObj (if (= (vla-get-Invisible attributeObj) :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-27 04:58
