每个维度都能够覆盖由维度样式分配给它的设置。以下属性可用于大多数维度对象:
为对齐的尺寸输入用户定义的后缀本示例在模型空间中创建一个对齐的维度,并使用 Suffix 属性允许用户更改维度的文本后缀。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("AddDimensionTextSuffix")> _
Public Sub AddDimensionTextSuffix()
'' Get the current database
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create the aligned dimension
Using acAliDim As AlignedDimension = New AlignedDimension()
acAliDim.XLine1Point = New Point3d(0, 5, 0)
acAliDim.XLine2Point = New Point3d(5, 5, 0)
acAliDim.DimLinePoint = New Point3d(5, 7, 0)
acAliDim.DimensionStyle = acCurDb.Dimstyle
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acAliDim)
acTrans.AddNewlyCreatedDBObject(acAliDim, True)
'' Append a suffix to the dimension text
Dim pStrOpts As PromptStringOptions = New PromptStringOptions("")
pStrOpts.Message = vbLf & "Enter a new text suffix for the dimension: "
pStrOpts.AllowSpaces = True
Dim pStrRes As PromptResult = acDoc.Editor.GetString(pStrOpts)
If pStrRes.Status = PromptStatus.OK Then
acAliDim.Suffix = pStrRes.StringResult
End If
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("AddDimensionTextSuffix")]
public static void AddDimensionTextSuffix()
// Get the current database
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create the aligned dimension
using (AlignedDimension acAliDim = new AlignedDimension())
acAliDim.XLine1Point = new Point3d(0, 5, 0);
acAliDim.XLine2Point = new Point3d(5, 5, 0);
acAliDim.DimLinePoint = new Point3d(5, 7, 0);
acAliDim.DimensionStyle = acCurDb.Dimstyle;
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acAliDim);
acTrans.AddNewlyCreatedDBObject(acAliDim, true);
// Append a suffix to the dimension text
PromptStringOptions pStrOpts = new PromptStringOptions("");
pStrOpts.Message = "\nEnter a new text suffix for the dimension: ";
pStrOpts.AllowSpaces = true;
PromptResult pStrRes = acDoc.Editor.GetString(pStrOpts);
if (pStrRes.Status == PromptStatus.OK)
acAliDim.Suffix = pStrRes.StringResult;
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub AddDimensionTextSuffix()
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim suffix As String
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5: point2(1) = 5: point2(2) = 0
Set dimObj = ThisDrawing.ModelSpace. _
AddDimAligned(point1, point2, location)
' Allow the user to change the text suffix for the dimension
suffix = ThisDrawing.Utility. _
GetString(True, vbLf & "Enter a new text " & _
"suffix for the dimension: ")
' Apply the change to the dimension
dimObj.TextSuffix = suffix
相关概念父主题: |
GMT+8, 2026-11-13 09:22
