ImageVisibility 属性 (ActiveX)
指定图像可见性是打开还是关闭。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论在当前绘图会话中不需要图像可见性时,可以通过关闭图像可见性来提高重绘速度。不显示或绘制隐藏的图像;仅显示绘图边界。您可以选择隐藏图像,而不考虑当前视口坐标系,或者特别是当图像与当前视口坐标系不正交(对齐)时。 例子VBA: Sub Example_ImageVisibility()
' This example inserts a raster image and finds the current status
' of ImageVisibility for the image. It then changes the ImageVisibility
' status of the image.
' This example uses the "2d Projected Polylines.jpg" found in the Sample
' directory. If you do not have the image, or if it is located
' in a different directory, insert a valid path and name for the
' imageName variable below.
Dim scalefactor As Double
Dim rotAngleInDegree As Double, rotAngle As Double
Dim imageName As String
Dim raster As AcadRasterImage
imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
scalefactor = 1#
rotAngleInDegree = 0#
rotAngle = rotAngleInDegree * 3.141592 / 180#
On Error Resume Next
' Creates a raster image in model space
Set raster = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
If Err.Description = "File error" Then
MsgBox imageName & " could not be found."
Exit Sub
End If
' Find the current ImageVisibility
ThisDrawing.Regen True
MsgBox "The ImageVisibility is currently set to: " & raster.ImageVisibility, vbInformation
' Change the ImageVisibility
If (raster.ImageVisibility) Then
raster.ImageVisibility = False
Else
raster.ImageVisibility = True
End If
MsgBox "The ImageVisibility is now set to: " & raster.ImageVisibility, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_ImageVisibility()
;; This example inserts a raster image and finds the current status
;; of ImageVisibility for the image. It then changes the ImageVisibility
;; status of the image.
;; This example uses the "2d Projected Polylines.jpg" found in the Sample
;; directory. If you do not have the image, or if it is located
;; in a different directory, insert a valid path and name for the
;; imageName variable below.
(setq insertionPoint (vlax-3d-point 2 2 0)
imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
scalefactor 1
rotAngle (/ (* 0 3.141592 180)))
;; Creates a raster image in model space
(if (/= (findfile imageName) nil)
(progn
(setq raster (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotAngle))
;; Find the current ImageVisibility
(vla-Regen doc :vlax-true)
(alert (strcat "The ImageVisibility is currently set to: " (if (= (vla-get-ImageVisibility raster) :vlax-true) "True" "False")))
;; Change the ImageVisibility
(vla-put-ImageVisibility raster :vlax-false)
(vla-put-ImageVisibility raster :vlax-true)
(alert (strcat "The ImageVisibility is now set to: " (if (= (vla-get-ImageVisibility raster) :vlax-true) "True" "False")))
(alert (strcat imageName " could not be found."))
GMT+8, 2026-10-28 06:10
