ImageHeight 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 683| 评论: 0|原作者: admin|来自: AutoCAD
指定光栅图像的高度。
object.ImageHeight
类型:GeomapImage、RasterImage、Wipeout
此属性应用于的对象。
只读:不
类型:双
光栅图像的高度。
此属性与属性类似。该属性指定图像的高度(以像素为单位)。此属性指定图像的高度(以当前单位为单位)。HeightHeight
Sub Example_ImageHeight()
    ' This example adds a raster image in model space and then finds
    ' the height and width of the image.
    ' This example uses the "2d Projected Polylines.jpg" found in the Sample
    ' directory. If you do not have this image, or if it is located
    ' in a different directory, insert a valid path and file name
    ' for the imageName variable below.
    Dim scalefactor As Double
    Dim rotationAngle As Double
    Dim imageName As String
    Dim rasterObj As AcadRasterImage
    imageName = "C:/AutoCAD/sample/2d Projected Polylines.jpg"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0#
    scalefactor = 1#
    rotationAngle = 0
    ' Creates a raster image in model space
    Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
    ' Find the height and width of the raster image
    Dim height As Variant
    Dim width As Variant
    height = rasterObj.ImageHeight
    width = rasterObj.ImageWidth
    MsgBox "Raster image: " & rasterObj.ImageFile & vbCrLf & _
           "ImageHeight: " & Str(height) & vbCrLf & _
           "ImageWidth: " & Str(width)
(defun c:Example_ImageHeight()
    ;; This example adds a raster image in model space and then finds
    ;; the height and width of the image.
    ;; This example uses the "2d Projected Polylines.jpg" found in the Sample
    ;; directory. If you do not have this image, or if it is located
    ;; in a different directory, insert a valid path and file name
    ;; for the imageName variable below.
    (setq insertionPoint (vlax-3d-point 5 5 0)
          imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
          scalefactor 1
          rotationAngle 0)
    ;; Creates a raster image in model space
    (if (/= (findfile imageName) nil)
        (progn
            (setq rasterObj (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotationAngle))
	    ;; Find the height and width of the raster image
	    (setq height (vla-get-ImageHeight rasterObj)
	          width (vla-get-ImageWidth rasterObj))
	    (alert (strcat "Raster image: " (vla-get-ImageFile rasterObj)
	                   "\nImageHeight: " (rtos height 2)
	                   "\nImageWidth: " (rtos width 2)))
        (alert (strcat imageName " could not be found."))
GMT+8, 2026-10-27 06:33
