HWND 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 699| 评论: 0|原作者: admin|来自: AutoCAD
HWND 属性 (ActiveX)
获取窗口框架的窗口控点。
object.HWND
类型:应用程序,文档
此属性应用于的对象。
只读:是的
类型:Long_PTR
窗框的把手。
Sub Example_HWND()
    ' This example returns the handle (Hwnd) of a document window. The handle can be
    ' used with WindowsAPI calls, or with ActiveX components that require a handle
    ' to a window.
    ' If there are no open documents, then exit
    If Documents.Count = 0 Then
        MsgBox "There are no open documents!"
        Exit Sub
    End If
    MsgBox "The HWND of the active document is: " & ActiveDocument.HWND
(defun c:Example_HWND()
    ;; This example returns the handle (Hwnd) of a document window. The handle can be
    ;; used with WindowsAPI calls, or with ActiveX components that require a handle
    ;; to a window.
    (alert (strcat "The HWND of the active document is: " (itoa (vla-get-HWND doc))))
GMT+8, 2026-10-27 01:21
