HelpString 属性 (ActiveX)
指定工具栏、工具栏项或菜单项的帮助字符串。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 工具栏、工具栏项或菜单项的帮助字符串。 言论帮助字符串是用户加亮显示菜单项时显示在 AutoCAD 状态行中的文本字符串。 例子VBA: Sub Example_HelpString()
' This example creates a new toolbar called "TestToolbar" and inserts a
' button into it. The HelpString property of the toolbar is then
' read and changed.
' To remove the toolbar after execution of this macro, use the Customize Menu
' option from the Tools menu.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new toolbar
Dim newToolBar As AcadToolbar
Set newToolBar = currMenuGroup.Toolbars.Add("TestToolbar")
' Add a button to the new toolbar.
Dim newButton1 As AcadToolbarItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newButton1 = newToolBar.AddToolbarButton("", "NewButton1", "Open a file.", openMacro)
' Display the toolbar
newToolBar.Visible = True
' Read the current value of the Help string
MsgBox "The current HelpString for the toolbar button is: " & newButton1.HelpString
' Change the value of the Help string
newButton1.HelpString = "Use this toolbar button to Open a file."
' Read the new value of the Help string
MsgBox "The new HelpString for the toolbar button is: " & newButton1.HelpString
可视化 LISP: (vl-load-com)
(defun c:Example_HelpString()
;; This example creates a new toolbar called "TestToolbar" and inserts a
;; button into it. The HelpString property of the toolbar is then
;; read and changed.
;; To remove the toolbar after execution of this macro, use the Customize Menu
;; option from the Tools menu.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new toolbar
(setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
;; Add a button to the new toolbar.
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newButton1 (vla-AddToolbarButton newToolBar "" "NewButton1" "Open a file." openMacro))
;; Display the toolbar
(vla-put-Visible newToolBar :vlax-true)
;; Read the current value of the Help string
(alert (strcat "The current HelpString for the toolbar button is: " (vla-get-HelpString newButton1)))
;; Change the value of the Help string
(vla-put-HelpString newButton1 "Use this toolbar button to Open a file.")
;; Read the new value of the Help string
(alert (strcat "The new HelpString for the toolbar button is: " (vla-get-HelpString newButton1)))
GMT+8, 2026-10-27 04:52
