HelpFilePath 属性 (ActiveX)
指定 AutoCAD 帮助文件的位置。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 AutoCAD 帮助文件的位置。 言论此特性指定 AutoCAD 帮助文件的驱动器、路径和文件名。 例子VBA: Sub Example_HelpFilePath()
' HelpFilePath. It then changes the value, and finally
Dim currHelpFilePath As String
Dim newHelpFilePath As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current HelpFilePath value
currHelpFilePath = preferences.Files.HelpFilePath
MsgBox "The current value for HelpFilePath is " & currHelpFilePath, vbInformation, "HelpFilePath Example"
' Change the value for HelpFilePath
newHelpFilePath = "C:/AutoCAD/Help"
preferences.Files.HelpFilePath = newHelpFilePath
MsgBox "The new value for HelpFilePath is " & newHelpFilePath, vbInformation, "HelpFilePath Example"
' Reset HelpFilePath to its original value
preferences.Files.HelpFilePath = currHelpFilePath
MsgBox "The HelpFilePath value is reset to " & currHelpFilePath, vbInformation, "HelpFilePath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_HelpFilePath()
;; HelpFilePath. It then changes the value, and finally
;; Retrieve the current HelpFilePath value
(setq currHelpFilePath (vla-get-HelpFilePath (vla-get-Files preferences)))
(alert (strcat "The current value for HelpFilePath is " currHelpFilePath))
;; Change the value for HelpFilePath
(setq newHelpFilePath "C:/AutoCAD/Help")
(vla-put-HelpFilePath (vla-get-Files preferences) newHelpFilePath)
(alert (strcat "The new value for HelpFilePath is " newHelpFilePath))
;; Reset HelpFilePath to its original value
(vla-put-HelpFilePath (vla-get-Files preferences) currHelpFilePath)
(alert (strcat "The HelpFilePath value is reset to " currHelpFilePath))
GMT+8, 2026-10-28 04:49
