HasExtensionDictionary 属性 (ActiveX)
确定对象是否具有与之关联的扩展字典。 支持的平台:仅限 Windows 签名VBA: object.HasExtensionDictionary
属性值只读:是的 类型:布尔
言论您可以为对象创建扩展字典,也可以使用该方法查询现有扩展字典。GetExtensionDictionary 例子VBA: Sub Example_HasExtensionDictionary()
' This example will iterate through each object in the current drawing and
' determine whether that object has an associated Extension Dictionary
Dim DrawingObject As AcadObject
Dim ExtensionDictionaryResults As String
' Make sure this drawing contains objects before continuing
If ThisDrawing.ModelSpace.count = 0 Then
MsgBox "There are no objects in the current drawing."
Exit Sub
End If
For Each DrawingObject In ThisDrawing.ModelSpace
' Determine whether object contains Extension Dictionary
Select Case DrawingObject.HasExtensionDictionary
Case True
ExtensionDictionaryResults = ExtensionDictionaryResults & _
DrawingObject.ObjectName & _
" has an associated Extension Dictionary" & vbCrLf
Case False
ExtensionDictionaryResults = ExtensionDictionaryResults _
& DrawingObject.ObjectName & _
" does not have an associated Extension Dictionary" & vbCrLf
End Select
Next
MsgBox ExtensionDictionaryResults
可视化 LISP: (vl-load-com)
(defun c:Example_HasExtensionDictionary()
;; This example will iterate through each object in the current drawing and
;; determine whether that object has an associated Extension Dictionary
;; Make sure this drawing contains objects before continuing
(if (= (vla-get-Count modelSpace) 0)
(alert "There are no objects in the current drawing.")
(progn
(setq ExtensionDictionaryResults "")
(vlax-for DrawingObject modelSpace
;; Determine whether object contains Extension Dictionary
(cond
((= (vla-get-HasExtensionDictionary DrawingObject) :vlax-true)
(setq ExtensionDictionaryResults (strcat ExtensionDictionaryResults
(vla-get-ObjectName DrawingObject)
" has an associated Extension Dictionary.\n")))
((= (vla-get-HasExtensionDictionary DrawingObject) :vlax-false)
" does not have an associated Extension Dictionary.\n")))
(alert ExtensionDictionaryResults)
GMT+8, 2026-10-27 09:50
