GripColorSelected 属性 (ActiveX)
指定所选夹点的颜色。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acColor 控制选定的夹具(绘制为填充框)。有效范围为 1 到 255,或此处列出的常量之一:
言论此属性的初始值为 12。 注意:此属性的值存储在 GRIPHOT 系统变量中。
例子VBA: Sub Example_GripColorSelected()
' This example reads and modifies the preference value that controls
' the color of selected grips.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the selection preferences object
Set ACADPref = ThisDrawing.Application.preferences.Selection
originalValue = ACADPref.GripColorSelected
MsgBox "The GripColorSelected preference is set to: " & originalValue
' Modify the GripColorSelected preference by setting it to green
ACADPref.GripColorSelected = acGreen
newValue = ACADPref.GripColorSelected
MsgBox "The GripColorSelected preference has been set to: " & newValue
' this preference in effect
ACADPref.GripColorSelected = originalValue
MsgBox "The GripColorSelected preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_GripColorSelected()
;; This example reads and modifies the preference value that controls
;; the color of selected grips.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the selection preferences object
(setq ACADPref (vla-get-Selection (vla-get-preferences acadObj)))
(setq originalValue (vla-get-GripColorSelected ACADPref))
(alert (strcat "The GripColorSelected preference is set to: " (itoa originalValue)))
;; Modify the GripColorSelected preference by setting it to green
(vla-put-GripColorSelected ACADPref acGreen)
(setq newValue (vla-get-GripColorSelected ACADPref))
(alert (strcat "The GripColorSelected preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-GripColorSelected ACADPref originalValue)
(alert (strcat "The GripColorSelected preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-27 05:45
