GraphicsWinModelBackgrndColor 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 734| 评论: 0|原作者: admin|来自: AutoCAD
指定模型空间窗口的背景色。
object.GraphicsWinModelBackgrndColor
类型:首选项显示
此属性应用于的对象。
只读:不
类型:OLE_COLOR(常量)
  • vb黑色
  • vb红色
  • vb黄色
  • vb绿色
  • vb青色
  • vbBlue的
  • vb品红色
  • vb白色
此属性的默认颜色为 。vbBlack
Sub Example_GraphicsWinModelBackgrndColor()
    ' GraphicsWinModelBackgrndColor. It then changes the value, and finally
    Dim currGraphicsWinModelBackgrndColor As OLE_COLOR
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current GraphicsWinModelBackgrndColor value
    currGraphicsWinModelBackgrndColor = preferences.DISPLAY.GraphicsWinModelBackgrndColor
    MsgBox "The current value for GraphicsWinModelBackgrndColor is " _
            & preferences.DISPLAY.GraphicsWinModelBackgrndColor, vbInformation, "GraphicsWinModelBackgrndColor Example"
    ' Change the value for GraphicsWinModelBackgrndColor
    preferences.DISPLAY.GraphicsWinModelBackgrndColor = 16
    MsgBox "The new value for GraphicsWinModelBackgrndColor is " _
    ' Reset GraphicsWinModelBackgrndColor to its original value
    preferences.DISPLAY.GraphicsWinModelBackgrndColor = currGraphicsWinModelBackgrndColor
    MsgBox "The GraphicsWinModelBackgrndColor value is reset to " _
(defun c:Example_GraphicsWinModelBackgrndColor()
    ;; GraphicsWinModelBackgrndColor. It then changes the value, and finally
    ;; Retrieve the current GraphicsWinModelBackgrndColor value
    (setq currGraphicsWinModelBackgrndColor (vlax-variant-change-type (vla-get-GraphicsWinModelBackgrndColor (vla-get-Display preferences)) vlax-vbLong))
    (alert (strcat "The current value for GraphicsWinModelBackgrndColor is " (itoa (vlax-variant-value currGraphicsWinModelBackgrndColor))))
    ;; Change the value for GraphicsWinModelBackgrndColor
    (vla-put-GraphicsWinModelBackgrndColor ACADPref (vlax-make-variant 127 19))
    (setq newValue (vlax-variant-change-type (vla-get-GraphicsWinModelBackgrndColor ACADPref) vlax-vbLong))
    (alert (strcat "The new value for GraphicsWinModelBackgrndColor is " (itoa (vlax-variant-value newValue))))
    ;; Reset GraphicsWinModelBackgrndColor to its original value
    (vla-put-GraphicsWinModelBackgrndColor ACADPref currGraphicsWinModelBackgrndColor)
    (alert (strcat "The GraphicsWinModelBackgrndColor value is reset to " (itoa (vlax-variant-value currGraphicsWinModelBackgrndColor))))
GMT+8, 2026-10-27 13:08
