弧长尺寸测量沿圆弧的长度,并显示带有弧符号的尺寸文本,该符号位于弧上方或继续上方。当需要标注圆弧的实际长度而不仅仅是其起点和终点之间的距离时,可以使用圆弧长度尺寸。 通过创建对象的实例来创建弧长半径尺寸。创建对象的实例时,它需要一组定义维度的参数。创建新对象时,必须提供以下参数:ArcDimensionArcDimensionArcDimension
注意:DIMARCSYM 系统变量控制是否显示圆弧符号以及该符号相对于尺寸文本的显示位置。
创建弧长尺寸本示例在模型空间中创建弧长尺寸。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateArcLengthDimension")> _
Public Sub CreateArcLengthDimension()
'' Get the current database
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create an arc length dimension
Using acArcDim As ArcDimension = New ArcDimension(New Point3d(4.5, 1.5, 0), _
New Point3d(8, 4.25, 0), _
New Point3d(0, 2, 0), _
New Point3d(5, 7, 0), _
"<>", _
acCurDb.Dimstyle)
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acArcDim)
acTrans.AddNewlyCreatedDBObject(acArcDim, True)
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("CreateArcLengthDimension")]
public static void CreateArcLengthDimension()
// Get the current database
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create an arc length dimension
using (ArcDimension acArcDim = new ArcDimension(new Point3d(4.5, 1.5, 0),
new Point3d(8, 4.25, 0),
new Point3d(0, 2, 0),
new Point3d(5, 7, 0),
acCurDb.Dimstyle))
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acArcDim);
acTrans.AddNewlyCreatedDBObject(acArcDim, true);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateArcLengthDimension()
Dim dimObj As AcadDimArcLength
Dim arcCenterPoint(0 To 2) As Double
Dim firstPoint(0 To 2) As Double
Dim secondPoint(0 To 2) As Double
Dim arcPoint(0 To 2) As Double
' Define the dimension
arcCenterPoint(0) = 4.5: arcCenterPoint(1) = 1.5: arcCenterPoint(2) = 0
firstPoint(0) = 8: firstPoint(1) = 4.25: firstPoint(2) = 0
secondPoint(0) = 0: secondPoint(1) = 2: secondPoint(2) = 0
arcPoint(0) = 5: arcPoint(1) = 7: arcPoint(2) = 0
' Create the arc length dimension in Model space
Set dimObj = ThisDrawing.ModelSpace. _
AddDimArc(arcCenterPoint, firstPoint, _
secondPoint, arcPoint)
ZoomAll
相关概念父主题: |
GMT+8, 2026-10-28 15:31
