FullName 属性 (ActiveX)
获取应用程序或文档的名称,包括路径。 支持的平台:仅限 Windows 属性值只读:是的 类型:字符串 应用程序或文档的名称和路径。 言论没有其他评论。 例子VBA: Sub Example_FullName()
' This example uses the FullName property to find
' the full name of the current drawing, and of
' the application.
' Find the full name of current drawing file including path.
' (If the drawing has not been saved, this name will be blank.)
Dim docName As String
docName = ThisDrawing.FullName
MsgBox "The full name of the current drawing is " & docName, , "FullName Example"
' Find the full name of application
Dim appName As String
appName = ThisDrawing.Application.FullName
MsgBox "The full name of the current application is " & appName, , "FullName Example"
可视化 LISP: (vl-load-com)
(defun c:Example_FullName()
;; This example uses the FullName property to find
;; the full name of the current drawing, and of
;; the application.
;; Find the full name of current drawing file including path.
;; (If the drawing has not been saved, this name will be blank.)
(setq docName (vla-get-FullName doc))
(alert (strcat "The full name of the current drawing is " docName))
;; Find the full name of application
(setq appName (vla-get-FullName acadObj))
(alert (strcat "The full name of the current application is " appName))
GMT+8, 2026-10-27 05:19
