FullCRCValidation 属性 (ActiveX)
指定每次将对象读入图形时是否应执行循环冗余校验 (CRC)。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 如果图形已损坏,并且您怀疑存在硬件问题或AutoCAD错误,请设置为 。FullCRCValidationTrue 例子VBA: Sub Example_FullCRCValidation()
' FullCRCValidation. It then changes the value, and finally
Dim currFullCRCValidation As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current FullCRCValidation value
currFullCRCValidation = preferences.OpenSave.FullCRCValidation
MsgBox "The current value for FullCRCValidation is " & preferences.OpenSave.FullCRCValidation, vbInformation, "FullCRCValidation Example"
' Change the value for FullCRCValidation
preferences.OpenSave.FullCRCValidation = Not (currFullCRCValidation)
MsgBox "The new value for FullCRCValidation is " & preferences.OpenSave.FullCRCValidation, vbInformation, "FullCRCValidation Example"
' Reset FullCRCValidation to its original value
preferences.OpenSave.FullCRCValidation = currFullCRCValidation
MsgBox "The FullCRCValidation value is reset to " & preferences.OpenSave.FullCRCValidation, vbInformation, "FullCRCValidation Example"
可视化 LISP: (vl-load-com)
(defun c:Example_FullCRCValidation()
;; FullCRCValidation. It then changes the value, and finally
;; Retrieve the current FullCRCValidation value
(setq currFullCRCValidation (vla-get-FullCRCValidation (vla-get-OpenSave preferences)))
(alert (strcat "The current value for FullCRCValidation is " (if (= currFullCRCValidation :vlax-true) "True" "False")))
;; Change the value for FullCRCValidation
(setq newFullCRCValidation (if (= currFullCRCValidation :vlax-true) :vlax-false :vlax-true))
(vla-put-FullCRCValidation (vla-get-OpenSave preferences) newFullCRCValidation)
(alert (strcat "The new value for FullCRCValidation is " (if (= newFullCRCValidation :vlax-true) "True" "False")))
;; Reset FullCRCValidation to its original value
(vla-put-FullCRCValidation (vla-get-OpenSave preferences) currFullCRCValidation)
(alert (strcat "The FullCRCValidation value is reset to " (if (= currFullCRCValidation :vlax-true) "True" "False")))
GMT+8, 2026-10-27 14:30
