FractionFormat 属性 (ActiveX)
指定尺寸和公差中分数值的格式。 支持的平台:仅限 Windows 签名VBA: object.FractionFormat
属性值只读:不 类型:枚举acDimFractionType
言论当属性设置为 或 时,将使用此属性。UnitsFormatacDimLArchitecturalacDimLFractional 注意:此属性将覆盖给定尺寸的 DIMFRAC 系统变量的值。
例子VBA: Sub Example_FractionFormat()
' uses FractionFormat to cycle through some fractional formats
' for the dimension.
' * Note the appearance of the "1/2" component of the dimension
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Switch to a mode that works with the FractionFormat property
dimObj.UnitsFormat = acDimLArchitectural
' Cycle through some common fractional formats
dimObj.FractionFormat = acDiagonal ' Change format to Diagonal
MsgBox "The dimension format is now set to diagonal"
dimObj.FractionFormat = acHorizontal ' Change format to Horizontal
MsgBox "The dimension format is now set to horizontal"
dimObj.FractionFormat = acNotStacked ' Change format to NotStacked
MsgBox "The dimension format is now unstacked"
可视化 LISP: (vl-load-com)
(defun c:Example_FractionFormat()
;; uses FractionFormat to cycle through some fractional formats
;; for the dimension.
;; * Note the appearance of the "1/2" component of the dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5.5 5 0)
(vla-ZoomAll acadObj)
;; Switch to a mode that works with the FractionFormat property
(vla-put-UnitsFormat dimObj acDimLArchitectural)
;; Cycle through some common fractional formats
(vla-put-FractionFormat dimObj acDiagonal) ;; Change format to Diagonal
(alert "The dimension format is now set to diagonal")
(vla-put-FractionFormat dimObj acHorizontal) ;; Change format to Horizontal
(alert "The dimension format is now set to horizontal")
(vla-put-FractionFormat dimObj acNotStacked) ;; Change format to NotStacked
(alert "The dimension format is now unstacked")
GMT+8, 2026-10-27 05:43
