ForceLineInside 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 859| 评论: 0|原作者: admin|来自: AutoCAD
指定是否在扩展线之间绘制尺寸线,即使文本放置在扩展线之外也是如此。
object.ForceLineInside
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:当箭头放置在测量点之外时,在测量点之间绘制尺寸线。
  • False:当箭头放置在被测点之外时,不要在被测点之间绘制尺寸线。
此属性的初始值为 。False
对于半径和直径尺寸(当属性设置为 时),此属性在圆或圆弧内绘制尺寸线和箭头,并将文本和引线放在外部。TextInsideFalse
注意:此属性将覆盖给定维度的 DIMTOFL 系统变量的值。
Sub Example_ForceLineInside()
    ' This example creates an aligned dimension in model space
    ' and toggles dimension lines to be drawn between extension lines
    Dim dimObj As AcadDimAligned
    Dim CurrentValue As String
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Read and display current line suppression information
    CurrentValue = IIf(dimObj.ForceLineInside, "are", "are not")
    MsgBox "Dimension lines " & CurrentValue & " forced between the extension lines"
    ' Force the display of dimension lines between the extension lines
    dimObj.ForceLineInside = True
    MsgBox "Dimension lines are forced between the extension lines"
    ' Do not force the display of dimension lines between the extension lines (default)
    dimObj.ForceLineInside = False
    MsgBox "Dimension lines are not forced between the extension lines"
(defun c:Example_ForceLineInside()
    ;; This example creates an aligned dimension in model space
    ;; and toggles dimension lines to be drawn between extension lines
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current line suppression information
    (setq CurrentValue (if (= (vla-get-ForceLineInside dimObj) :vlax-true) "are" "are not"))
    (alert (strcat "Dimension lines " CurrentValue " forced between the extension lines"))
    ;; Force the display of dimension lines between the extension lines
    (vla-put-ForceLineInside dimObj :vlax-true)
    (alert "Dimension lines are forced between the extension lines")
    ;; Do not force the display of dimension lines between the extension lines (default)
    (vla-put-ForceLineInside dimObj :vlax-false)
    (alert "Dimension lines are not forced between the extension lines")
GMT+8, 2026-11-21 13:01
