FontFileMap 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 649| 评论: 0|原作者: admin|来自: AutoCAD
指定文件的位置,用于定义 AutoCAD 应如何转换未找到的字体。
object.FontFileMap
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
字体映射文件的驱动器、路径和文件名。
Sub Example_FontFileMap()
    ' FontFileMap. It then changes the value, and finally
    Dim currFontFileMap As String
    Dim newFontFileMap As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current FontFileMap value
    currFontFileMap = preferences.Files.FontFileMap
    MsgBox "The current value for FontFileMap is " & currFontFileMap, vbInformation, "FontFileMap Example"
    ' Change the value for FontFileMap
    newFontFileMap = "TestFontFileMap.fmp"
    preferences.Files.FontFileMap = newFontFileMap
    MsgBox "The new value for FontFileMap is " & newFontFileMap, vbInformation, "FontFileMap Example"
    ' Reset FontFileMap to its original value
    preferences.Files.FontFileMap = currFontFileMap
    MsgBox "The FontFileMap value is reset to " & currFontFileMap, vbInformation, "FontFileMap Example"
(defun c:Example_FontFileMap()
    ;; FontFileMap. It then changes the value, and finally
    ;; Retrieve the current FontFileMap value
    (setq currFontFileMap (vla-get-FontFileMap (vla-get-Files preferences)))
    (alert (strcat "The current value for FontFileMap is " currFontFileMap))
    ;; Change the value for FontFileMap
    ;; The file being specified must exist or an error will be generated
    (setq newFontFileMap "C:\\AutoCAD\\TestFontFileMap.fmp")
    (vla-put-FontFileMap (vla-get-Files preferences) newFontFileMap)
    (alert (strcat "The new value for FontFileMap is " newFontFileMap))
    ;; Reset FontFileMap to its original value
    (vla-put-FontFileMap (vla-get-Files preferences) currFontFileMap)
    (alert (strcat "The FontFileMap value is reset to " currFontFileMap))
GMT+8, 2026-10-28 21:01
