Flyout 属性 (ActiveX)
获取与浮出控件工具栏项关联的工具栏。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Flyout()
' This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
' It then creates a new Toolbar(TestMenu) with a Toolbar button that will act
' as a flyout. The examples sets the Flyout menu to an existing Toolbar menu.
' The Toolbar will automatically be displayed and will display the UCS menu
' as a flyout.
Dim currMenuGroup As acadMenuGroup
Dim newToolBar As AcadToolbar, newToolBarFlyoutButton As AcadToolbarItem
On Error GoTo ERRORTRAP
' Use MenuGroups property to obtain reference to main AutoCAD menu
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
' Create a new Toolbar in this group
Set newToolBar = currMenuGroup.Toolbars.Add("TestMenu")
' Add new button to TestMenu that will link to the Flyout menu
' * NOTE: Set the macro name to the name of the flyout toolbar because
' setting it to an empty string causes an error. The paremeter
' is actually ignored when the style is flyout, but must have any value other than "".
Set newToolBarFlyoutButton = newToolBar.AddToolbarButton(newToolBar.count + 1, "Flyout", "Flyout", "UCS", True)
' Link the existing toolbar "UCS" as the flyout for the new toolbar button
' * NOTE: To change the flyout, simply change the MenuGroup and Toolbar name below
newToolBarFlyoutButton.AttachToolbarToFlyout "ACAD", "UCS"
MsgBox "The flyout attached to the Test menu is " & newToolBarFlyoutButton.Flyout.name
Exit Sub
ERRORTRAP:
MsgBox "The following error has occurred: " & Err.Description
可视化 LISP: (vl-load-com)
(defun c:Example_Flyout()
;; This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
;; It then creates a new Toolbar(TestMenu) with a Toolbar button that will act
;; as a flyout. The examples sets the Flyout menu to an existing Toolbar menu.
;; The Toolbar will automatically be displayed and will display the UCS menu
;; as a flyout.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create a new Toolbar in this group
(setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
;; Add new button to TestMenu that will link to the Flyout menu
;; * NOTE: Set the macro name to the name of the flyout toolbar because
;; setting it to an empty string causes an error. The paremeter
;; is actually ignored when the style is flyout, but must have any value other than "".
(setq newToolBarFlyoutButton (vla-AddToolbarButton newToolBar (1+ (vla-get-Count newToolBar)) "Flyout" "Flyout" "UCS" :vlax-true))
;; Link the existing toolbar "UCS" as the flyout for the new toolbar button
;; * NOTE: To change the flyout, simply change the MenuGroup and Toolbar name below
(vla-AttachToolbarToFlyout newToolBarFlyoutButton "ACAD" "UCS")
(alert (strcat "The flyout attached to the Test menu is " (vla-get-Name (vla-get-Flyout newToolBarFlyoutButton))))
GMT+8, 2026-10-28 09:04
