FitTolerance 属性 (ActiveX)
使用新的公差值将样条调整到现有点。 支持的平台:仅限 Windows 属性值只读:不 类型:双 拟合公差不能为负数。 言论如果拟合容差设置为零,则样条曲线将穿过所有拟合点。如果提供大于零的值,则曲线可以在指定的容差范围内通过拟合点。 例子VBA: Sub Example_FitTolerance()
' This example creates a spline object in model space.
' It then changes the FitTolerance property of that spline.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
' Find the current FitTolerance value
Dim currFitTolerance As Double
currFitTolerance = splineObj.FitTolerance
MsgBox "The current FitTolerance is " & currFitTolerance, vbInformation, "FitTolerance Example"
' Change the fit tolerance value
splineObj.FitTolerance = 5
ZoomAll
MsgBox "The FitTolerance is now " & splineObj.FitTolerance, vbInformation, "FitTolerance Example"
可视化 LISP: (vl-load-com)
(defun c:Example_FitTolerance()
;; This example creates a spline object in model space.
;; It then changes the FitTolerance property of that spline.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
;; Create new Spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Find the current FitTolerance value
(setq currFitTolerance (vla-get-FitTolerance splineObj))
(alert (strcat "The current FitTolerance is " (rtos currFitTolerance 2)))
;; Change the fit tolerance value
(vla-put-FitTolerance splineObj 5)
(alert (strcat "The FitTolerance is now " (rtos (vla-get-FitTolerance splineObj) 2)))
GMT+8, 2026-11-15 12:41
