FitPoints 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 783| 评论: 0|原作者: admin|来自: AutoCAD
指定样条曲线的拟合点。
object.FitPoints
类型:样条曲线
此属性应用于的对象。
只读:不
类型:变体(双打数组)
表示样条曲线拟合点的 3D WCS 坐标数组。
拟合点定义样条曲线的路径。您可以使用该属性更改给定拟合点的容差。您可以使用该方法添加拟合点。您可以使用该方法删除拟合点。您可以使用该方法查询拟合点的位置。您可以使用该方法更改给定拟合点的位置。FitToleranceAddFitPointDeleteFitPointGetFitPointSetFitPoint
Sub Example_FitPoints()
    ' This example creates a Spline object in model space, reads the fit points
    ' of the Spline and then modifies the fit points of the Spline.
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
    Dim FPoints(0 To 8) As Double
    Dim UserMessage As String
    Dim fitPoints As Variant
    Dim iCount As Long, iPoint As Integer
    Dim NewFP(0 To 2) As Double
    ' Define the Spline object
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    FPoints(0) = 0: FPoints(1) = 0: FPoints(2) = 0
    FPoints(3) = 5:   FPoints(4) = 5: FPoints(5) = 0
    FPoints(6) = 10: FPoints(7) = 0: FPoints(8) = 0
    ' Create new Spline object
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(FPoints, startTan, endTan)
    ' Display fit points for this Spline
    GoSub DISPLAYPOINTS
    ' Modify an existing fit point for this Spline
    fitPoints(0) = 3
    splineObj.fitPoints = fitPoints
    ' Now add a new fit point
    NewFP(0) = 15: NewFP(1) = 4: NewFP(2) = 0
    splineObj.AddFitPoint splineObj.NumberOfFitPoints + 1, NewFP
    ' Display new fit points for this Spline
    GoSub DISPLAYPOINTS
    Exit Sub
DISPLAYPOINTS:
    fitPoints = splineObj.fitPoints
    ' Display in groups of three
    UserMessage = ""
    iPoint = 0
    For iCount = 0 To UBound(fitPoints) Step 3
        iPoint = iPoint + 1
        UserMessage = UserMessage & iPoint & ")" & vbTab
        UserMessage = UserMessage & fitPoints(iCount)
        UserMessage = UserMessage & ", " & fitPoints(iCount + 1)
        UserMessage = UserMessage & ", " & fitPoints(iCount + 2)
        UserMessage = UserMessage & vbCrLf
    Next
    MsgBox "The " & splineObj.NumberOfFitPoints & " Spline fit points are: " & vbCrLf & vbCrLf & UserMessage
    Return
(defun c:Example_FitPoints()
    ;; This example creates a Spline object in model space, reads the fit points
    ;; of the Spline and then modifies the fit points of the Spline.
    ;; Define the Spline object
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display fit points for this Spline
    (setq fitPoints (vlax-variant-value (vla-get-FitPoints splineObj)))
    ;; Display in groups of three
    (setq UserMessage ""
          iPoint 0
	         iCount 0)
    (while (>= (vlax-safearray-get-u-bound fitPoints 1) iCount)
        (setq iPoint (1+ iPoint))
        (setq UserMessage (strcat UserMessage (itoa iPoint) ")  "
                                  (rtos (vlax-safearray-get-element fitPoints iCount) 2) ",  "
                                  (rtos (vlax-safearray-get-element fitPoints (+ iCount 1)) 2) ",  "
                                  (rtos (vlax-safearray-get-element fitPoints (+ iCount 2)) 2) "\n"))
        (setq iCount (+ iCount 3))
    (alert (strcat "The " (itoa (vla-get-NumberOfFitPoints splineObj)) " Spline fit points are: \n\n" UserMessage))
    ;; Modify an existing fit point for this Spline
    (vlax-safearray-put-element fitPoints 0 3)
    (vla-put-FitPoints splineObj fitPoints)
    ;; Now add a new fit point
    (setq NewFP (vlax-3d-point 15 4 0))
    (vla-AddFitPoint splineObj (+ (vla-get-NumberOfFitPoints splineObj) 1) NewFP)
    ;; Display new fit points for this Spline
          iPoint 0
	         iCount 0)
GMT+8, 2026-10-28 09:03
