Fit 属性 (ActiveX)
根据扩展线之间的可用空间,指定文本和箭头在扩展线内或外部的位置。 支持的平台:仅限 Windows 签名VBA: object.Fit
属性值只读:不 类型:枚举acDimFit
言论此属性的初始值为 。acBestFit 该属性设置当扩展行内没有空间容纳文本和箭头时移动文本和箭头的优先级。Fit 注意:此属性将覆盖给定维度的 DIMATFIT 系统变量的值。
例子VBA: Sub Example_Fit()
' This example creates an aligned dimension in model space
' and cycles the text fit of the dimension to a couple of common values
Dim dimObj As AcadDimAligned
Dim CurrentFit As String
' Define the dimension
point2(0) = 6: point2(1) = 5: point2(2) = 0
' Read and display current dimension line fit information
Select Case dimObj.Fit
Case acTextAndArrows: CurrentFit = "Text and Arrows"
Case acArrowsOnly: CurrentFit = "Arrows Only"
Case acTextOnly: CurrentFit = "Text Only"
Case acBestFit: CurrentFit = "Best Fit"
End Select
MsgBox "The current dimension fit is set to: " & CurrentFit
' Change the fit to arrows only
dimObj.Fit = acArrowsOnly
MsgBox "The dimension fit has been changed to arrows only"
' Change the fit to text only
dimObj.Fit = acTextOnly
MsgBox "The dimension fit has been changed to text only"
可视化 LISP: (vl-load-com)
(defun c:Example_Fit()
;; This example creates an aligned dimension in model space
;; and cycles the text fit of the dimension to a couple of common values
;; Define the dimension
point2 (vlax-3d-point 6 5 0)
(vla-ZoomAll acadObj)
;; Read and display current dimension line fit information
(setq CurrentFit (vla-get-Fit dimObj))
(cond
((= acTextAndArrows CurrentFit)(setq CurrentFit "Text and Arrows"))
((= acArrowsOnly CurrentFit)(setq CurrentFit "Arrows Only"))
((= acTextOnly CurrentFit)(setq CurrentFit "Text Only"))
((= acBestFit CurrentFit)(setq CurrentFit "Best Fit"))
(setq CurrentFit (itoa CurrentFit))
(alert (strcat "The current dimension fit is set to: " CurrentFit))
;; Change the fit to arrows only
(vla-put-Fit dimObj acArrowsOnly)
(alert "The dimension fit has been changed to arrows only")
;; Change the fit to text only
(vla-put-Fit dimObj acTextOnly)
(alert "The dimension fit has been changed to text only")
GMT+8, 2026-10-28 12:31
