Files 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 571| 评论: 0|原作者: admin|来自: AutoCAD
Files 属性 (ActiveX)
获取 PreferencesFiles 对象。
object.Files
类型:首选项
此属性应用于的对象。
只读:是的
类型:PreferencesFiles
获取对象。PreferencesFiles
该对象保存存储在注册表中的“选项”对话框的“文件”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesFilesDatabasePreferences
Sub Example_Files()
    ' This example obtains a reference to the Files Preferences object
    ' from the Application Preferences object, and reads one of the File
    ' preferences
    Dim ACADPref As AcadPreferencesFiles
    ' Obtain a reference to the Files Preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Files
    MsgBox "We now have access to the properties and methods of the Files Preferences object!"
    MsgBox "The File preference AutoSavePath is set to: " & ACADPref.AutoSavePath
(defun c:Example_Files()
    ;; This example obtains a reference to the Files Preferences object
    ;; from the Application Preferences object, and reads one of the File
    ;; preferences
    ;; Obtain a reference to the Files Preferences object
    (setq ACADPref (vla-get-Files preferences))
    (alert "We now have access to the properties and methods of the Files Preferences object!")
    (alert (strcat "The File preference AutoSavePath is set to: " (vla-get-AutoSavePath ACADPref)))
GMT+8, 2026-10-27 04:24
