ExtLine1EndPoint 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 675| 评论: 0|原作者: admin|来自: AutoCAD
指定第一个扩展行的端点。
object.ExtLine1EndPoint
类型:Dim3PointAngular、DimAngular
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示第一条延伸线的端点的 3D 坐标。
和 属性包含扩展线的端点。如果给定维度不存在延伸线,则这些点将等于 和 。ExtLine1EndPointExtLine2EndPointExtLine1StartPointExtLine2StartPoint
Sub Example_ExtLine1EndPoint()
    ' This example creates an angular dimension. It then changes
    ' the location of the ExtLine1EndPoint.
    Dim dimObj As AcadDimAngular
    Dim angVert(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double
    Dim SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the dimension
    angVert(0) = 0#: angVert(1) = 5#: angVert(2) = 0#
    FirstPoint(0) = 1#: FirstPoint(1) = 7#: FirstPoint(2) = 0#
    SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
    TextPoint(0) = 3#: TextPoint(1) = 5#: TextPoint(2) = 0#
    ' Create the angular dimension in model space
    Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint)
    ZoomAll
    MsgBox "The current value of ExtLine1EndPoint is " & dimObj.ExtLine1EndPoint(0) & ", " & dimObj.ExtLine1EndPoint(1) & ", " & dimObj.ExtLine1EndPoint(2), vbInformation, "ExtLine1EndPoint Example"
    ' Change the endpoint of the first extension line
    SecondPoint(0) = 0: SecondPoint(1) = 3: SecondPoint(2) = 0
    dimObj.ExtLine1EndPoint = SecondPoint
    dimObj.Update
    ' Return the endpoint of the first extension line
    ' Note that the return value is a Variant
    Dim retPnt As Variant
    retPnt = dimObj.ExtLine1EndPoint
    MsgBox "The new value of ExtLine1EndPoint is " & dimObj.ExtLine1EndPoint(0) & ", " & dimObj.ExtLine1EndPoint(1) & ", " & dimObj.ExtLine1EndPoint(2), vbInformation, "ExtLine1EndPoint Example"
(defun c:Example_ExtLine1EndPoint()
    ;; This example creates an angular dimension. It then changes
    ;; the location of the ExtLine1EndPoint.
    ;; Define the dimension
    (setq AngleVertex (vlax-3d-point 0 5 0)
          FirstPoint (vlax-3d-point 1 7 0)
          SecondPoint (vlax-3d-point 1 3 0)
          TextPoint (vlax-3d-point 3 5 0))
    ;; Create the angular dimension in model space
    (setq dimObj (vla-AddDimAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    (setq extLineEndPoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1EndPoint dimObj))))
    (alert (strcat "The current value of ExtLine1EndPoint is " (rtos (nth 0 extLineEndPoint) 2) ", "
		                                               (rtos (nth 1 extLineEndPoint) 2) ", "
		                                               (rtos (nth 2 extLineEndPoint) 2)))
    ;; Change the endpoint of the first extension line
    (setq SecondPoint (vlax-3d-point 0 3 0))
    (vla-put-ExtLine1EndPoint dimObj SecondPoint)
    (vla-Update dimObj)
    ;; Return the endpoint of the first extension line
    ;; Note that the return value is a Variant
    (setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1EndPoint dimObj))))
    (alert (strcat "The new value of ExtLine1EndPoint is " (rtos (nth 0 retPnt) 2) ", "
		                                           (rtos (nth 1 retPnt) 2) ", "
		                                           (rtos (nth 2 retPnt) 2)))
GMT+8, 2026-10-28 21:04
