ElevationPaperSpace 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 1051| 评论: 0|原作者: admin|来自: AutoCAD
指定图纸空间中的高程设置。
object.ElevationPaperSpace
类型:数据库、文档
此属性应用于的对象。
只读:不
类型:双
图纸空间的高程。
当前高程是每当需要 3D 点但仅提供 X 和 Y 值时使用的 Z 值。当前高程分别在模型空间和图纸空间中维护。
Sub Example_ElevationPaperSpace()
    ' This example changes the paper space elevation of the current drawing
    ' and then resets it to the original value.
    Dim currElevation As Double
    currElevation = ThisDrawing.ElevationPaperSpace
    MsgBox "The current paper space elevation is " & ThisDrawing.ElevationPaperSpace, vbInformation, "ElevationpaperSpace Example"
    ' Change the elevation
    ThisDrawing.ElevationPaperSpace = currElevation + 2
    MsgBox "The new paper space elevation is " & ThisDrawing.ElevationPaperSpace, vbInformation, "ElevationpaperSpace Example"
    ' Reset the elevation to its original value
    MsgBox "The paper space elevation is reset to " & ThisDrawing.ElevationPaperSpace, vbInformation, "ElevationPaperSpace Example"
(defun c:Example_ElevationPaperSpace()
    ;; This example changes the paper space elevation of the current drawing
    ;; and then resets it to the original value.
    (setq currElevation (vla-get-ElevationPaperSpace doc))
    (alert (strcat "The current paper space elevation is " (rtos currElevation 2)))
    ;; Change the elevation
    (vla-put-ElevationPaperSpace doc (+ currElevation 2))
    (alert (strcat "The new paper space elevation is " (rtos (vla-get-ElevationPaperSpace doc) 2)))
    ;; Reset the elevation to its original value
    (vla-put-ElevationPaperSpace doc currElevation)
    (alert (strcat "The paper space elevation is reset to " (rtos (vla-get-ElevationPaperSpace doc) 2)))
GMT+8, 2026-10-27 06:29
