DriversPath 属性 (ActiveX)
指定AutoCAD在其中查找视频显示、指点设备、打印机和绘图仪的ADI设备驱动程序的目录。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 设备驱动程序所在的目录。为每个路径指定驱动器号和路径。用分号 (;). 言论没有其他评论。 例子VBA: Sub Example_DriversPath()
' DriversPath. It then changes the value, and finally
Dim currDriversPath As String
Dim newDriversPath As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current DriversPath value
currDriversPath = preferences.Files.DriversPath
MsgBox "The current value for DriversPath is " & currDriversPath, vbInformation, "DriversPath Example"
' Change the value for DriversPath
newDriversPath = "TestDriversPath"
preferences.Files.DriversPath = newDriversPath
MsgBox "The new value for DriversPath is " & newDriversPath, vbInformation, "DriversPath Example"
' Reset DriversPath to its original value
preferences.Files.DriversPath = currDriversPath
MsgBox "The DriversPath value is reset to " & currDriversPath, vbInformation, "DriversPath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DriversPath()
;; DriversPath. It then changes the value, and finally
;; Retrieve the current DriversPath value
(setq currDriversPath (vla-get-DriversPath (vla-get-Files preferences)))
(alert (strcat "The current value for DriversPath is " currDriversPath))
;; Change the value for DriversPath
(setq newDriversPath "TestDriversPath")
(vla-put-DriversPath (vla-get-Files preferences) newDriversPath)
(alert (strcat "The new value for DriversPath is " newDriversPath))
;; Reset DriversPath to its original value
(vla-put-DriversPath (vla-get-Files preferences) currDriversPath)
(alert (strcat "The DriversPath value is reset to " currDriversPath))
GMT+8, 2026-10-27 04:51
