DrawingDirection 属性 (ActiveX)
指定读取多行文本段落的方向。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acDrawingDirection
言论对于英语或西班牙语等语言,文本从左到右水平阅读。对于中文或日语等语言,有时文本是垂直阅读的,从上到下。AutoCAD将根据此特性设置绘制文本。 ![]() 从左到右 ![]() 从上到下 设置 、 和 保留供将来使用,不能在此版本中使用。acRightToLeftacBottomToTopacByStyle 例子VBA: Sub Example_DrawingDirection()
' This example changes the drawing direction for an MText object
' in model space.
Dim MTextObj As AcadMText
Dim corner1(0 To 2) As Double
Dim width As Double
Dim text As String
' Define the MText object
corner1(0) = 0#: corner1(1) = 6#: corner1(2) = 0#
width = 7
text = "This is a text String."
' Create the MText object in model space
Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner1, width, text)
ZoomAll
'Change the drawing direction of the MText object
MTextObj.DrawingDirection = acLeftToRight
ZoomAll
MsgBox "The DrawingDirection of the text is left to right.", vbInformation, "DrawingDirection Example"
MTextObj.DrawingDirection = acTopToBottom
ZoomAll
MsgBox "The DrawingDirection of the text is top to bottom.", vbInformation, "DrawingDirection Example"
' Return the drawing direction
Dim retDirection As Integer
retDirection = MTextObj.DrawingDirection
可视化 LISP: (vl-load-com)
(defun c:Example_DrawingDirection()
;; This example changes the drawing direction for an MText object
;; in model space.
;; Define the MText object
(setq corner1 (vlax-3d-point 0 6 0)
width 7
text "This is a text String.")
;; Create the MText object in model space
(setq MTextObj (vla-AddMText modelSpace corner1 width text))
(vla-ZoomAll acadObj)
;; Change the drawing direction of the MText object
(vla-put-DrawingDirection MTextObj acLeftToRight)
(alert "The DrawingDirection of the text is left to right.")
(vla-put-DrawingDirection MTextObj acTopToBottom)
(alert "The DrawingDirection of the text is top to bottom.")
;; Return the drawing direction
(setq retDirection (vla-get-DrawingDirection MTextObj))
(alert (strcat "The current value of DrawingDirection: " (itoa retDirection)))
GMT+8, 2026-10-28 01:48
