Drafting 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 658| 评论: 0|原作者: admin|来自: AutoCAD
获取 PreferencesDrafting 对象。
object.Drafting
类型:首选项
此属性应用于的对象。
只读:是的
类型:首选项起草
获取对象。PreferencesDrafting
该对象包含存储在注册表中的“选项”对话框的“绘图”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesDraftingDatabasePreferences
Sub Example_Drafting()
    ' This example obtains a reference to the Drafting Preferences object
    ' from the Application Preferences object, and reads one of the Drafting
    ' preferences
    Dim ACADPref As AcadPreferencesDrafting
    ' Obtain a reference to the Drafting Preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Drafting
    MsgBox "We now have access to the properties and methods of the Drafting Preferences object!"
    MsgBox "The Drafting preference AutoSnapTooltip is set to: " & ACADPref.AutoSnapTooltip
(defun c:Example_Drafting()
    ;; This example obtains a reference to the Drafting Preferences object
    ;; from the Application Preferences object, and reads one of the Drafting
    ;; preferences
    ;; Obtain a reference to the Drafting Preferences object
    (setq ACADPref (vla-get-Drafting preferences))
    (alert "We now have access to the properties and methods of the Drafting Preferences object!")
    (alert (strcat "The Drafting preference AutoSnapTooltip is set to: " (if (= (vla-get-AutoSnapTooltip ACADPref) :vlax-true) "True" "false")))
GMT+8, 2026-10-27 05:11
