DogLegged 属性 (ActiveX)
狗腿的状态。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_DogLeg()
Dim oML As AcadMLeader
Dim points(0 To 14) As Double
' Define the leader points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
Dim i As Long
Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
oML.DogLegged = True
oML.DoglegLength = 1.3
MsgBox "The dog-leg length is " & oML.DoglegLength
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_DogLeg()
;; Define the leader points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 14)))
(vlax-safearray-fill points '(1 1 0
1 2 0
2 2 0
3 2 0
4 4 0
(setq i 0)
(setq oML (vla-AddMLeader modelSpace points i))
(vla-put-DogLegged oML :vlax-true)
(vla-put-DoglegLength oML 1.3)
(alert (strcat "The dog-leg length is " (rtos (vla-get-DoglegLength oML) 2)))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 09:49
