Documents 属性 (ActiveX)
获取 Documents 集合。 支持的平台:仅限 Windows 言论该集合允许您访问当前 AutoCAD 任务中的所有文档或图形。Documents 例子VBA: Sub Example_Documents()
' This example obtains a reference to the Documents collection
' and displays information about the loaded documents.
Dim Document As AcadDocument
Dim msg As String
msg = vbCrLf
' Cycle through the Documents collection and retrieve the names
' of the loaded documents
For Each Document In Documents
msg = msg & Document.Name & vbCrLf
Next
' Display loaded document information
If Documents.Count > 0 Then
MsgBox "The loaded documents are: " & msg
Else
MsgBox "There are no loaded documents!"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_Documents()
;; This example obtains a reference to the Documents collection
;; and displays information about the loaded documents.
;; Cycle through the Documents collection and retrieve the names
;; of the loaded documents
(setq msg "")
(vlax-for Document (vla-get-Documents acadObj)
(setq msg (strcat msg "\n" (vla-get-Name Document)))
;; Display loaded document information
(if (> (vla-get-Count (vla-get-Documents acadObj)))
(alert (strcat "The loaded documents are: " msg))
(alert "There are no loaded documents!")
GMT+8, 2026-10-27 07:16
