DisplayScreenMenu 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 723| 评论: 0|原作者: admin|来自: AutoCAD
指定是否在绘图窗口的右侧显示屏幕菜单。(已过时)
object.DisplayScreenMenu
类型:首选项显示
此属性应用于的对象。
只读:
类型:布尔
  • True:显示屏幕菜单。
  • False:不显示屏幕菜单。
此属性的初始值为 。False
Sub Example_DisplayScreenMenu()
    ' DisplayScreenMenu. It then changes the value, and finally
    Dim currDisplayScreenMenu As Boolean
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current DisplayScreenMenu value
    currDisplayScreenMenu = preferences.Display.DisplayScreenMenu
    MsgBox "The current value for DisplayScreenMenu is " & preferences.DISPLAY.DisplayScreenMenu, vbInformation, "DisplayScreenMenu Example"
    ' Change the value for DisplayScreenMenu
    preferences.DISPLAY.DisplayScreenMenu = Not (currDisplayScreenMenu)
    MsgBox "The new value for DisplayScreenMenu is " & preferences.DISPLAY.DisplayScreenMenu, vbInformation, "DisplayScreenMenu Example"
    ' Reset DisplayScreenMenu to its original value
    preferences.DISPLAY.DisplayScreenMenu = currDisplayScreenMenu
    MsgBox "The DisplayScreenMenu value is reset to " & preferences.DISPLAY.DisplayScreenMenu, vbInformation, "DisplayScreenMenu Example"
(defun c:Example_DisplayScreenMenu()
    ;; DisplayScreenMenu. It then changes the value, and finally
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    ;; Retrieve the current DisplayScreenMenu value
    (setq currDisplayScreenMenu (vla-get-DisplayScreenMenu ACADPref))
    (alert (strcat "The current value for DisplayScreenMenu is " (if (= currDisplayScreenMenu :vlax-true) "True" "False")))
    ;; Change the value for DisplayScreenMenu
    (setq newValue (if (= currDisplayScreenMenu :vlax-true) :vlax-false :vlax-true))
    (vla-put-DisplayScreenMenu ACADPref newValue)
    (alert (strcat "The new value for DisplayScreenMenu is " (if (= newValue :vlax-true) "True" "False")))
    ;; Reset DisplayScreenMenu to its original value
    (vla-put-DisplayScreenMenu ACADPref currDisplayScreenMenu)
    (alert (strcat "The DisplayScreenMenu value is reset to " (if (= currDisplayScreenMenu :vlax-true) "True" "False")))
GMT+8, 2026-9-9 14:00
