DisplayLocked 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 976| 评论: 0|原作者: admin|来自: AutoCAD
指定视口是否锁定。
object.DisplayLocked
类型: PViewport
此属性应用于的对象。
只读:不
类型:布尔
  • True:视口已锁定。
  • False:视口未锁定。
Sub Example_DisplayLocked()
    ' This example scans the current drawing paper space Viewports
    ' and displays whether or not any of them are locked.
    Dim pviewportObj As Object
    Dim msg As String, DisplayState As String
    ' Make sure this drawing contains paper space viewports before continuing
    If ThisDrawing.PaperSpace.Count = 0 Then
        MsgBox "There are no paper space viewports in the current drawing."
        Exit Sub
    End If
    ' Go through each PViewport object in the drawing paper space
    ' and determine whether the paper space viewport is locked or not
    For Each pviewportObj In ThisDrawing.PaperSpace
        ' Determine if this is a paper space viewport
        If pviewportObj.ObjectName = "AcDbViewport" Then
            ' Determine if this paper space viewport is clipped
            DisplayState = IIf(pviewportObj.DisplayLocked, " is locked", " is not locked")
            msg = msg & "PViewport ID " & pviewportObj.ObjectID & DisplayState & vbCrLf
        End If
    Next
    ' Display locked state of paper space Viewports
    MsgBox msg
(defun c:Example_DisplayLocked()
    ;; This example scans the current drawing paper space Viewports
    ;; and displays whether or not any of them are locked.
    (setq paperSpace (vla-get-PaperSpace doc))
    ;; Make sure this drawing contains paper space viewports before continuing
    (if (= (vla-get-count paperSpace) 0)
        (alert "There are no paper space viewports in the current drawing.")
        (progn
	           (setq msg "")
	           ;; Go through each paper space viewport object in the drawing paper space
	           ;; and determine whether or not it is locked
	           (vlax-for pviewportObj paperSpace
	               ;; Determine whether this is a paper space viewport
	               (if (= (vla-get-ObjectName pviewportObj) "AcDbViewport")
	                   (progn
	                       ;; Determine whether this paper space viewport is locked
	                       (setq DisplayState (if (= (vla-get-DisplayLocked pviewportObj) :vlax-true) " is locked" " is not locked"))
		                      (setq ID (itoa (vla-get-ObjectID pviewportObj)))
	                       (setq msg (strcat msg "PViewport ID " ID DisplayState "\n"))
	           ;; Display locked state of paper space Viewports
	           (alert msg)
GMT+8, 2026-10-27 04:58
