DisplayLayoutTabs 属性 (ActiveX)
指定是否在绘图编辑器中显示“模型”和“布局”选项卡。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 例子VBA: Sub Example_DisplayLayoutTabs()
' This example reads and modifies the preference value that controls
' the display of the Model and layout tabs. When finished, this example
' resets the preference value back to its original value.
Dim ACADPref As AcadPreferencesDisplay
' Get the display preferences object
Set ACADPref = ThisDrawing.Application.Preferences.DISPLAY
originalValue = ACADPref.DisplayLayoutTabs
MsgBox "The DisplayLayoutTabs preference is set to: " & originalValue
' Modify the DisplayLayoutTabs preference by toggling the value
ACADPref.DisplayLayoutTabs = Not (originalValue)
newValue = ACADPref.DisplayLayoutTabs
MsgBox "The DisplayLayoutTabs preference has been set to: " & newValue
' this preference in effect
ACADPref.DisplayLayoutTabs = originalValue
MsgBox "The DisplayLayoutTabs preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_DisplayLayoutTabs()
;; This example reads and modifies the preference value that controls
;; the display of the Model and layout tabs. When finished, this example
;; resets the preference value back to its original value.
;; Get the display preferences object
(setq ACADPref (vla-get-Display preferences))
(setq originalValue (vla-get-DisplayLayoutTabs ACADPref))
(alert (strcat "The DisplayLayoutTabs preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the DisplayLayoutTabs preference by toggling the value
(vla-put-DisplayLayoutTabs ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-DisplayLayoutTabs ACADPref))
(alert (strcat "The DisplayLayoutTabs preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-DisplayLayoutTabs ACADPref originalValue)
(alert (strcat "The DisplayLayoutTabs preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 04:47
