Display 属性 (ActiveX)
获取 PreferencesDisplay 对象。 支持的平台:仅限 Windows 言论该对象保存存储在注册表中的“选项”对话框的“显示”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesDisplayDatabasePreferences 例子VBA: Sub Example_Display()
' This example obtains a reference to the Display Preferences object
' from the Application Preferences object, and reads one of the Display
' preferences
Dim ACADPref As AcadPreferencesDisplay
' Obtain a reference to the Display Preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Display
MsgBox "We now have access to the properties and methods of the Display Preferences object!"
MsgBox "The Display preference CursorSize is set to: " & ACADPref.CursorSize
可视化 LISP: (vl-load-com)
(defun c:Example_Display()
;; This example obtains a reference to the Display Preferences object
;; from the Application Preferences object, and reads one of the Display
;; preferences
;; Obtain a reference to the Display Preferences object
(setq ACADPref (vla-get-Display preferences))
(alert "We now have access to the properties and methods of the Display Preferences object!")
(alert (strcat "The Display preference CursorSize is set to: " (itoa (vla-get-CursorSize ACADPref))))
GMT+8, 2026-10-27 04:53
