DirectionVector 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 602| 评论: 0|原作者: admin|来自: AutoCAD
指定光线、公差或 x 线通过矢量的方向。
object.DirectionVector
类型:射线、公差、XLine
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
射线、公差或构造线 (XLine) 的方向。
Sub Example_DirectionVector()
    ' This example creates a ray and then changes the direction vector
    ' for the ray.
    Dim rayObj As AcadRay
    Dim basePoint(0 To 2) As Double
    Dim SecondPoint(0 To 2) As Double
    Dim newDirectionVec(0 To 2) As Double
    basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
    SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
    ' Create a Ray object in model space
    Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
    ZoomAll
    MsgBox "The ray has a direction vector of " & rayObj.DirectionVector(0) & ", " & rayObj.DirectionVector(1) & ", " & rayObj.DirectionVector(2), vbInformation, "DirectionVector Example"
    ' Change the direction vector
    newDirectionVec(0) = 3#: newDirectionVec(1) = 1#: newDirectionVec(2) = 0#
    rayObj.DirectionVector = newDirectionVec
    ' Query the new direction vector for the Ray
    Dim retDir As Variant            ' Note that return from DirectionVector property is Variant and not a SafeArray
    retDir = rayObj.DirectionVector
    ThisDrawing.Regen True
    MsgBox "The direction vector of the ray has been changed to " & rayObj.DirectionVector(0) & ", " & rayObj.DirectionVector(1) & ", " & rayObj.DirectionVector(2), vbInformation, "DirectionVector Example"
(defun c:Example_DirectionVector()
    ;; This example creates a ray and then changes the direction vector
    ;; for the ray.
    (setq basePoint (vlax-3d-point 3 3 0)
          SecondPoint (vlax-3d-point 1 3 0))
    ;; Create a Ray object in model space
    (setq rayObj (vla-AddRay modelSpace basePoint SecondPoint))
    (vla-ZoomAll acadObj)
    (setq vDirection (vlax-safearray->list (vlax-variant-value (vla-get-DirectionVector rayObj))))
    (alert (strcat "The ray has a direction vector of "
	           "\n" (rtos (nth 0 vDirection) 2) "," (rtos (nth 1 vDirection) 2) "," (rtos (nth 2 vDirection) 2)))
    ;; Change the direction vector
    (setq newDirectionVec (vlax-3d-point 3 1 0))
    (vla-put-DirectionVector rayObj newDirectionVec)
    ;; Query the new direction vector for the Ray
    (setq retDir (vlax-safearray->list (vlax-variant-value (vla-get-DirectionVector rayObj))))
    (vla-Regen doc :vlax-true)
    (alert (strcat "The direction vector of the ray has been changed to "
	           "\n" (rtos (nth 0 retDir) 2) "," (rtos (nth 1 retDir) 2) "," (rtos (nth 2 retDir) 2)))
GMT+8, 2026-10-27 04:32
