Direction 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 672| 评论: 0|原作者: admin|来自: AutoCAD
指定绘图的 3D 可视化的查看方向或表格的方向矢量。
object.Direction
类型:ExtrudedSurface、PViewport、Table、View、Viewport
此属性应用于的对象。
只读:不
类型:变体
表对象:向量(X 轴,以 WCS 坐标表示)定义包含表的水平面。
所有其他对象:向量是一个三元素的双精度数组,用于定义可查看绘图的方向。
此属性使查看者能够查看绘图,就像从空间中的指定点回望原点 (0, 0, 0) 一样。此特性类似于 AutoCAD 中的 VPOINT 命令。
Sub Example_Direction()
    ' This example creates a circle in model space
    ' and changes the thickness of the circle. Once
    ' the thickness has been changed, the direction
    ' of the active viewport is changed so that the
    ' new thickness setting is visible.
    Dim circleObj As AcadCircle
    Dim radius As Double
    ' Define the circle
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ' Change the thickness of the circle
    circleObj.Thickness = 3
    ' Change the direction of the viewport so that you can
    ' view the change made to the thickness. Once you change
    ' the direction, you must reset the active viewport.
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
Sub example_tableDirection()
    Dim oMS As AcadModelSpace
    Set oMS = ThisDrawing.ModelSpace
    Dim oT As AcadTable
    Dim pt(2) As Double
    Set oT = oMS.AddTable(pt, 4, 5, 5, 20)
    ZoomExtents
    Dim vDirection As Variant
    vDirection = oT.Direction
    MsgBox "Table Direction vector is " & vbCrLf & vDirection(0) & "," & vDirection(1) & "," & vDirection(2)
    Dim vNewDirection(2) As Double
    vNewDirection(0) = 0
    vNewDirection(1) = 1
    vNewDirection(2) = 0
    oT.Direction = vNewDirection
    Dim vRetDirection As Variant
    vRetDirection = oT.Direction
    MsgBox "New Table Direction vector is " & vbCrLf & vRetDirection(0) & "," & vRetDirection(1) & "," & vRetDirection(2)
(defun c:Example_Direction()
    ;; This example creates a circle in model space
    ;; and changes the thickness of the circle. Once
    ;; the thickness has been changed, the direction
    ;; of the active viewport is changed so that the
    ;; new thickness setting is visible.
    ;; Define the circle
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    ;; Change the thickness of the circle
    (vla-put-Thickness circleObj 3)
    ;; Change the direction of the viewport so that you can
    ;; view the change made to the thickness. Once you change
    ;; the direction, you must reset the active viewport.
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
(defun c:Example_TableDirection()
    (setq pt (vlax-3d-point 0 0 0)
          oT (vla-AddTable modelSpace pt 4 5 5 20))
    (vla-ZoomExtents acadObj)
    (setq vDirection (vlax-safearray->list (vlax-variant-value (vla-get-Direction oT))))
    (alert (strcat "Table Direction vector is "
	           "\n" (rtos (nth 0 vDirection) 2) "," (rtos (nth 1 vDirection) 2) "," (rtos (nth 2 vDirection) 2)))
    (setq vNewDirection (vlax-3d-point 0 1 0))
    (vla-put-Direction oT vNewDirection)
    (setq vRetDirection (vlax-safearray->list (vlax-variant-value (vla-get-Direction oT))))
    (alert (strcat "New Table Direction vector is "
	           "\n" (rtos (nth 0 vRetDirection) 2) "," (rtos (nth 1 vRetDirection) 2) "," (rtos (nth 2 vRetDirection) 2)))
GMT+8, 2026-10-27 11:13
