DimLineSuppress 属性 (ActiveX)
指定禁止显示径向尺寸的尺寸线。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 当此属性设置为 时,将禁止显示扩展线和文本之间的尺寸线和箭头。True 注意:此属性将重写 DIMSD2 系统变量的值。
例子VBA: Sub Example_DimLineSuppress()
' This example creates a Radial Dimension in model space and
' uses the DimLineSuppress property to toggle the display
' of the dimension lines
Dim dimObj As AcadDimRadial
Dim center(0 To 2) As Double
Dim chordPoint(0 To 2) As Double
Dim leaderLen As Integer
' Define the dimension
center(0) = 0: center(1) = 0: center(2) = 0
chordPoint(0) = 5: chordPoint(1) = 5: chordPoint(2) = 0
leaderLen = 5
' Create the radial dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimRadial(center, chordPoint, leaderLen)
MsgBox "The radial dimension has been created.", vbInformation
dimObj.DimLineSuppress = Not (dimObj.DimLineSuppress)
MsgBox "The radial dimension appearance has been modified.", vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_DimLineSuppress()
;; This example creates a Radial Dimension in model space and
;; uses the DimLineSuppress property to toggle the display
;; of the dimension lines
;; Define the dimension
(setq center (vlax-3d-point 0 0 0)
chordPoint (vlax-3d-point 5 5 0)
leaderLen 5)
;; Create the radial dimension in model space
(setq dimObj (vla-AddDimRadial modelSpace center chordPoint leaderLen))
(vla-ZoomAll acadObj)
(alert "The radial dimension has been created.")
(vla-put-DimLineSuppress dimObj (if (= (vla-get-DimLineSuppress dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "The radial dimension appearance has been modified.")
GMT+8, 2026-10-27 04:30
