DimLineInside 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 691| 评论: 0|原作者: admin|来自: AutoCAD
仅指定延伸线内尺寸线的显示。
object.DimLineInside
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示延伸线外的尺寸线。
  • False:在延伸线外显示尺寸线。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMSOXD 系统变量的值。
Sub Example_DimLineInside()
    ' This example creates a DimAligned object in model space
    ' and toggles the dimension lines to be both allowed and disallowed
    ' outside the extension lines
    Dim dimObj As AcadDimAligned
    Dim CurrentValue As String
    ' Define the dimension
    point2(0) = 6: point2(1) = 5: point2(2) = 0
    ' Read and display current line suppression information
    CurrentValue = IIf(dimObj.DimLineInside, "are not", "are")
    MsgBox "Dimension lines " & CurrentValue & " allowed outside the extension lines"
    ' Suppress the display of dimension lines outside the extension lines
    dimObj.DimLineInside = True
    MsgBox "Dimension lines are not allowed outside the extension lines"
    ' Allow the display of dimension lines outside the extension lines (default)
    dimObj.DimLineInside = False
    MsgBox "Dimension lines are allowed outside the extension lines"
(defun c:Example_DimLineInside()
    ;; This example creates a DimAligned object in model space
    ;; and toggles the dimension lines to be both allowed and disallowed
    ;; outside the extension lines
    ;; Define the dimension
          point2 (vlax-3d-point 6 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current line suppression information
    (setq CurrentValue (if (= (vla-get-DimLineInside dimObj) :vlax-true) "are not" "are"))
    (alert (strcat "Dimension lines " CurrentValue " allowed outside the extension lines"))
    ;; Suppress the display of dimension lines outside the extension lines
    (vla-put-DimLineInside dimObj :vlax-true)
    (alert "Dimension lines are not allowed outside the extension lines")
    ;; Allow the display of dimension lines outside the extension lines (default)
    (vla-put-DimLineInside dimObj :vlax-false)
    (alert "Dimension lines are allowed outside the extension lines")
GMT+8, 2026-10-27 11:16
