DimLine1Suppress 属性 (ActiveX)
指定第一条尺寸线的隐含。 支持的平台:仅限 Windows 签名VBA: object.DimLine1Suppress
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 当此属性设置为 时,将禁止显示第一条延长线和文本之间的尺寸线和箭头。True 注意:此属性将覆盖给定维度的 DIMSD1 系统变量的值。
例子VBA: Sub Example_DimensionLine1Suppress()
' This example creates a Dim3PointAngular object in model space
' and suppresses the dimension lines using the DimensionLine1Suppress
' and DimensionLine2Suppress properties
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim Line1Suppressed As String, Line2Suppressed As String
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current line suppression information
Line1Suppressed = IIf(DimPointAngularObj.DimLine1Suppress, "is suppressed", "is not suppressed")
Line2Suppressed = IIf(DimPointAngularObj.DimLine2Suppress, "is suppressed", "is not suppressed")
MsgBox "Line one of the dimension " & Line1Suppressed & vbCrLf & _
"Line two of the dimension " & Line2Suppressed
' Suppress line one of the dimension
DimPointAngularObj.DimLine1Suppress = True
MsgBox "Line one of the dimension is now suppressed"
' Suppress line two of the dimension
DimPointAngularObj.DimLine2Suppress = True
MsgBox "Line two of the dimension is now suppressed"
' Turn both dimension lines back on
DimPointAngularObj.DimLine1Suppress = False
DimPointAngularObj.DimLine2Suppress = False
MsgBox "Both dimension lines are now visible again"
可视化 LISP: (vl-load-com)
(defun c:Example_DimensionLine1Suppress()
;; This example creates a Dim3PointAngular object in model space
;; and suppresses the dimension lines using the DimensionLine1Suppress
;; and DimensionLine2Suppress properties
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current line suppression information
(setq Line1Suppressed (if (= (vla-get-DimLine1Suppress DimPointAngularObj) :vlax-true) "is suppressed" "is not suppressed"))
(setq Line2Suppressed (if (= (vla-get-DimLine2Suppress DimPointAngularObj) :vlax-true) "is suppressed" "is not suppressed"))
(alert (strcat "Line one of the dimension " Line1Suppressed
"\nLine two of the dimension " Line2Suppressed))
;; Suppress line one of the dimension
(vla-put-DimLine1Suppress DimPointAngularObj :vlax-true)
(alert "Line one of the dimension is now suppressed")
;; Suppress line two of the dimension
(vla-put-DimLine2Suppress DimPointAngularObj :vlax-true)
(alert "Line two of the dimension is now suppressed")
;; Turn both dimension lines back on
(vla-put-DimLine1Suppress DimPointAngularObj :vlax-false)
(vla-put-DimLine2Suppress DimPointAngularObj :vlax-false)
(alert "Both dimension lines are now visible again")
GMT+8, 2026-11-15 11:48
