DimensionLineWeight 属性 (ActiveX)
指定尺寸线的线宽。 支持的平台:仅限 Windows 签名VBA: object.DimensionLineWeight 属性值只读:不 类型:枚举acLineWeight
言论此属性的初始值为 。acLnWtByBlock 仅当属性设置为 时,线宽设置才可见。LineweightDisplayTrue 例子VBA: Sub Example_DimensionLineWeight()
' This example creates a Dim3PointAngular object in model space
' and changes the dimension lineweight to a thicker value
' using the DimensionLineWeight property
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim oldLWSetting As Boolean
Dim CurrentSetting As String
' Turn on lineweight display so the changes can be seen
oldLWSetting = ThisDrawing.preferences.LineWeightDisplay
ThisDrawing.preferences.LineWeightDisplay = True
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current dimension lineweight
CurrentSetting = DimPointAngularObj.DimensionLineWeight
Select Case CurrentSetting
Case acLnWtByLayer: CurrentSetting = "ByLayer"
Case acLnWtByBlock: CurrentSetting = "ByBlock"
Case acLnWtByLwDefault: CurrentSetting = "ByDefault"
Case Else
End Select
MsgBox "The dimension lineweight setting for this object is currently set to: " & CurrentSetting
' Change the dimension lineweight
DimPointAngularObj.DimensionLineWeight = acLnWt100
MsgBox "The dimension lineweight setting for this object is now set to: " & DimPointAngularObj.DimensionLineWeight
' Return previous lineweight setting
ThisDrawing.preferences.LineWeightDisplay = oldLWSetting
可视化 LISP: (vl-load-com)
(defun c:Example_DimensionLineWeight()
;; This example creates a Dim3PointAngular object in model space
;; and changes the dimension lineweight to a thicker value
;; using the DimensionLineWeight property
(setq preferences (vla-get-Preferences doc))
;; Turn on lineweight display so the changes can be seen
(setq oldLWSetting (vla-get-LineWeightDisplay preferences))
(vla-put-LineWeightDisplay preferences :vlax-true)
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current dimension lineweight
(setq CurrentSetting (vla-get-DimensionLineWeight DimPointAngularObj))
(cond
((= acLnWtByLayer CurrentSetting)(setq CurrentSetting "ByLayer"))
((= acLnWtByBlock CurrentSetting)(setq CurrentSetting "ByBlock"))
((= acLnWtByLwDefault CurrentSetting)(setq CurrentSetting "ByDefault"))
(setq CurrentSetting (itoa CurrentSetting))
(alert (strcat "The dimension lineweight setting for this object is currently set to: " CurrentSetting))
;; Change the dimension lineweight
(vla-put-DimensionLineWeight DimPointAngularObj acLnWt100)
(alert (strcat "The dimension lineweight setting for this object is now set to: " (itoa (vla-get-DimensionLineWeight DimPointAngularObj))))
;; Return previous lineweight setting
(vla-put-DimensionLineWeight DimPointAngularObj oldLWSetting)
GMT+8, 2026-10-27 04:52
