DimensionLineExtend 属性 (ActiveX)
指定绘制倾斜描边而不是箭头时尺寸线延伸到延伸线之外的距离。 支持的平台:仅限 Windows 属性值只读:不 类型:双 一个正实数,指定将尺寸线延伸到延伸线之外的距离。 言论此属性的初始值为 0.0000。 注意:此属性将覆盖给定维度的 DIMDLE 系统变量的值。
例子VBA: Sub Example_DimensionLineExtend()
' uses DimensionLineExtend to specify the distance the dimension
' line extends beyond the extension line when oblique strokes are
' drawn instead of arrowheads
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 10.123: point2(1) = 5: point2(2) = 0
dimObj.Arrowhead1Type = acArrowOblique
dimObj.Arrowhead2Type = acArrowOblique
MsgBox "A new Dimension has been created. Press any key to extend the dimension lines."
' Round the distance of the alternate dimension to 0.50 of a unit
dimObj.DimensionLineExtend = 2
MsgBox "The dimension lines have been extended to: " & dimObj.DimensionLineExtend
可视化 LISP: (vl-load-com)
(defun c:Example_DimensionLineExtend()
;; uses DimensionLineExtend to specify the distance the dimension
;; line extends beyond the extension line when oblique strokes are
;; drawn instead of arrowheads
;; Define the dimension
point2 (vlax-3d-point 10.123 5 0)
(vla-put-Arrowhead1Type dimObj acArrowOblique)
(vla-put-Arrowhead2Type dimObj acArrowOblique)
(vla-ZoomAll acadObj)
(alert "A new Dimension has been created.")
;; Round the distance of the alternate dimension to 0.50 of a unit
(vla-put-DimensionLineExtend dimObj 2)
(alert (strcat "The dimension lines have been extended to: " (rtos (vla-get-DimensionLineExtend dimObj) 2)))
GMT+8, 2026-10-28 07:51
