Degree2 属性 (ActiveX)
指定样条的多项式表示的度数。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 介于 1 和 25 之间的整数(含 1 和 25)。 言论样条曲线的阶数等于样条曲线的度数加一 (+1)。 例子VBA: Sub Example_Degree()
' This example creates a spline and returns the degree
' of the spline's polynomial representation.
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ThisDrawing.Regen True
MsgBox "The degree of this Spline's polynomial representation is: " & splineObj.Degree, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_Degree()
;; This example creates a spline and returns the degree
;; of the spline's polynomial representation.
;; Define the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(0 0 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomExtents acadObj)
(vla-Regen doc :vlax-true)
(alert (strcat "The degree of this Spline's polynomial representation is: " (itoa (vla-get-Degree splineObj))))
GMT+8, 2026-10-27 13:07
