DefaultPlotStyleForObjects 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 759| 评论: 0|原作者: admin|来自: AutoCAD
指定新创建对象的默认打印样式名称。
object.DefaultPlotStyleForObjects
类型:首选项输出
此属性应用于的对象。
只读:不
类型:字符串
有效条目包括 “ByLayer”、“ByBlock”、“Normal” 或当前加载的打印样式中的任何样式名称。
此属性的初始值为“ByLayer”。
仅当设置为 时,此属性才可用。PlotPolicyacPolicyNamed
使用该属性查找当前打印样式。DefaultPlotStyleTable
注意:此属性的值存储在 DEFLPLSTYLE 系统变量中。
Sub Example_DefaultPlotStyleForObjects()
    ' This example reads and modifies the preference value that controls
    ' the default plot style name for newly created objects.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesOutput
    Dim originalPolicyValue As Variant, originalValue As Variant, newValue As Variant
    ' Get the output preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Output
    ' Set the default plot style to named plot styles
    originalPolicyValue = ACADPref.PlotPolicy
    ACADPref.PlotPolicy = acPolicyNamed
    originalValue = ACADPref.DefaultPlotStyleForObjects
    MsgBox "The DefaultPlotStyleForObjects preference is: " & originalValue
    ' Toggle and display the DefaultPlotStyleForObjects preference
    If ACADPref.DefaultPlotStyleForObjects = "ByBlock" Then
        ACADPref.DefaultPlotStyleForObjects = "Normal"
    Else
    End If
    newValue = ACADPref.DefaultPlotStyleForObjects
    MsgBox "The DefaultPlotStyleForObjects preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.DefaultPlotStyleForObjects = originalValue
    MsgBox "The DefaultPlotStyleForObjects preference was reset back to: " & originalValue
    ACADPref.PlotPolicy = originalPolicyValue
(defun c:Example_DefaultPlotStyleForObjects()
    ;; This example reads and modifies the preference value that controls
    ;; the default plot style name for newly created objects.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the output preferences object
    (setq ACADPref (vla-get-Output preferences))
    ;; Set the default plot style to named plot styles
    (setq originalPolicyValue (vla-get-PlotPolicy ACADPref))
    (vla-put-PlotPolicy ACADPref acPolicyNamed)
    (setq originalValue (vla-get-DefaultPlotStyleForObjects ACADPref))
    (alert (strcat "The DefaultPlotStyleForObjects preference is: " originalValue))
    ;; Toggle and display the DefaultPlotStyleForObjects preference
    (if (= (vla-get-DefaultPlotStyleForObjects ACADPref) "ByBlock")
        (vla-put-DefaultPlotStyleForObjects ACADPref "Normal")
        (vla-put-DefaultPlotStyleForObjects ACADPref "ByBlock")
    (setq newValue (vla-get-DefaultPlotStyleForObjects ACADPref))
    (alert (strcat "The DefaultPlotStyleForObjects preference has been set to: " newValue))
    ;;         this preference in effect
    (vla-put-DefaultPlotStyleForObjects ACADPref originalValue)
    (alert (strcat "The DefaultPlotStyleForObjects preference was reset back to: " originalValue))
    (vla-put-PlotPolicy ACADPref originalPolicyValue)
GMT+8, 2026-10-28 09:44
