DefaultPlotStyleForLayer 属性 (ActiveX)
指定新图形或使用早期版本的 AutoCAD 创建的图形的图纸的默认打印样式,这些图形从未以 AutoCAD 2000 或更高版本格式保存。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 您可以输入默认值“正常”,并输入在当前加载的打印样式表中定义的任何打印样式。 言论此属性的初始值为“Normal”。 仅当设置为 时,此属性才可用。PlotPolicyacPolicyNamed 使用该属性查找当前打印样式。DefaultPlotStyleTable 注意:此属性的值存储在 DEFLPLSTYLE 系统变量中。
例子VBA: Sub Example_DefaultPlotStyleForLayer()
' This example reads and modifies the preference value that controls
' the default plot style assigned to layers.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesOutput
Dim originalPolicyValue As Variant, originalValue As Variant, _
originalPlotStyleTableValue As Variant, newValue As Variant
' Get the output preferences object
Set ACADPref = ThisDrawing.Application.preferences.Output
' Set the default plot style to named plot styles
originalPolicyValue = ACADPref.PlotPolicy
ACADPref.PlotPolicy = acPolicyNamed
originalValue = ACADPref.DefaultPlotStyleForLayer
MsgBox "The DefaultPlotStyleForLayer preference is: " & originalValue
originalPlotStyleTableValue = ACADPref.DefaultPlotStyleTable
ACADPref.DefaultPlotStyleTable = "acad.stb"
' Toggle and display the DefaultPlotStyleForLayer preference
If ACADPref.DefaultPlotStyleForLayer = "Style 1" Then
ACADPref.DefaultPlotStyleForLayer = "Normal"
Else
End If
newValue = ACADPref.DefaultPlotStyleForLayer
MsgBox "The DefaultPlotStyleForLayer preference has been set to: " & newValue
' this preference in effect
ACADPref.DefaultPlotStyleForLayer = originalValue
MsgBox "The DefaultPlotStyleForLayer preference was reset back to: " & originalValue
' Restore the original plot style
ACADPref.PlotPolicy = originalPolicyValue
ACADPref.DefaultPlotStyleTable = originalPlotStyleTableValue
可视化 LISP: (vl-load-com)
(defun c:Example_DefaultPlotStyleForLayer()
;; This example reads and modifies the preference value that controls
;; the default plot style assigned to layers.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the output preferences object
(setq ACADPref (vla-get-Output preferences))
;; Set the default plot style to named plot styles
(setq originalPolicyValue (vla-get-PlotPolicy ACADPref))
(vla-put-PlotPolicy ACADPref acPolicyNamed)
(setq originalPlotStyleTableValue (vla-get-DefaultPlotStyleTable ACADPref))
(vla-put-DefaultPlotStyleTable ACADPref "acad.stb")
(setq originalValue (vla-get-DefaultPlotStyleForLayer ACADPref))
(alert (strcat "The DefaultPlotStyleForLayer preference is: " originalValue))
;; Toggle and display the DefaultPlotStyleForLayer preference
(if (= (vla-get-DefaultPlotStyleForLayer ACADPref) "Style 1")
(vla-put-DefaultPlotStyleForLayer ACADPref "Normal")
(vla-put-DefaultPlotStyleForLayer ACADPref "Style 1")
(setq newValue (vla-get-DefaultPlotStyleForLayer ACADPref))
(alert (strcat "The DefaultPlotStyleForLayer preference has been set to: " newValue))
;; this preference in effect
(vla-put-DefaultPlotStyleForLayer ACADPref originalValue)
(alert (strcat "The DefaultPlotStyleForLayer preference was reset back to: " originalValue))
;; Restore the original plot style
(vla-put-PlotPolicy ACADPref originalPolicyValue)
(vla-put-DefaultPlotStyleTable ACADPref originalPlotStyleTableValue)
GMT+8, 2026-10-27 13:07
